i have a vr exec and everytime i turn the aircon on i get like a gushing sound in the dash. it sounds like water trying to squeeze through a small pipe. it definately has something to do with the aircon because it only does it when i have it on. the aircon works fine otherwise. the sound gets louder when i floor the car or accelerate harder
what is this???
anything would help alot
cheers jordan
If the gushing noise doesn't happen when the temp control is turned to cold (fully clockwise) then that would confirm that it is air in the heater matrix....it should not happen when turned to cold as (in theory) the heater tap is turned off and no coolant flows thru the heater matrix.
