Results 1 to 17 of 17
Thread: Warning Light
    Smallies's Avatar
    Smallies is offline I hate carnies.
    VN Calais / 180SX
    Dec 2008
    Whyalla, SA.
    Default Warning Light
    Hey,
    Quite often when i use the brakes a warning light lights up.
    But my brakes and brake lights work fine.
    The symbol is tough to explain like this. ummm.
    Its a red light with a circle - inside the circle is a " ! " symbol. And theres a couple of lines below it.
    Whats it mean?
    VS S2 Ute
    Nov 2008
    Not the brake fluid level is it? Not sure if these have a sensor for that or not.
    Maybe when you are applying the brakes it is drawing enough fluid out of the res. to trigger the sensor.
    hsvpunk's Avatar
    hsvpunk is offline volunteer firefighter
    vy ss II M6
    Jan 2007
    Mornington, Vic
    check the fault codes, do a search on it.
    dont worry, il start a ride thread soon.
    vn calais, vs clubsport #137
    Jun 2005
    Quote Originally Posted by hsvpunk View Post
    the fault codes for what, its not bringing on his check engine light.
    Quote Originally Posted by Rod Wellard View Post
    i think hes pretty close to it, id say the level is down and its drawing in air.
    VX SS M6
    Jun 2005
    VS Berlina 3.8
    Dec 2008
    If it's anything like the Kingswoods, it might just mean that your brakes are wearing down. There's a "Brake Fail" light in Kingswoods that simply means that the brake pads/rotors are worn to the point that when you hit the brakes, the light activates because the calipers have to go in a certain distance (I think, don't quote me on that one).
    It doesn't mean that your brakes would stop working, it just might mean that it's time to replace a couple of things.
    Having said that, it could be fluid or bulbs.
    Smallies's Avatar
    VN Calais / 180SX
    Dec 2008
    Whyalla, SA.
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    If you have the owners manual the explanation will be in that.
    MY RIDE
    MY08 Subaru Liberty GT-B & VS Exec
    Dec 2005
    Glen Waverley VIC
    Sounds like the bulb fail light, meaning that one of your brake lights or tail lights is stuffed. Maybe get someone to stand behind the car whilst you depress the brakes to see if anything isn't lighting up.
    VZ Calais
    Aug 2005
    Mackay Qld
    I have a similar problem.
    When i drive at night, the light comes on.
    When i brake, it goes out & stays out for a little while.
    I posted up the same Q a while back.
    One of the forumers gave instructions as how to clear the fault.
    Sorry i can't remember how to do it, but it was simple.
    Cheers, Col.
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    on standard cars, the light will illuminate on brake fail. i experienced this when my brakes werent bled properly. very spongy pedal and had to pump the brakes to stop.
    on the Caprices, the above applies, but it also warns for a globe out. if your brakes are working fine, as others have suggested, its most likely a faulty globe
    Dec 2005
    Glen Waverley VIC
    Quote Originally Posted by ephect View Post
    Are you sure? I just checked the owners manual, and the brake fail light is separate to the bulb failure light. There is the handbrake warning light, then the brake fail light which only illuminates when you are actually cranking the engine over, not when you turn the ignition on ie when the rest of the lights come on, and then there is the bulb failure light which is different again.
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    yeap the
    handbrake light: is red, the letter P in a circle with brackets around it
    brake fail: is red , with a ! in a circle with brackets around it
    the bulb fail light, now im not 100% sure lol
    WH LS1 STATEO VR V6 STATEO & VR V6 BT1
    Nov 2007
    Adelaide-
    It means a light bulb is out . . Which one? you will need to find it . Could be a number plate bulb blown ? I had the same problem. Red light with an exclaimation !
    $PIMPIE PAULIE$
    - GEN 3 BABY -
  15. #15
    VZ Calais
    Aug 2005
    Mackay Qld
  16. #16
    Smallies's Avatar
    VN Calais / 180SX
    Dec 2008
    Whyalla, SA.
    I didnt think about number plate bulbs. I just had the brake lights checked. Theyre all sweet. Ill have another look tonight.
  17. #17
    VSII Esteem 3.8
    Sep 2008
    I have the same sorta problem mate. That little ! light has been there since i got the car. brakes work fine so i just ignore it :P
  1. Alternator Warning Light & ABS OFF Light
    By Harvs82 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-01-2007, 10:10 PM
  2. Tail light Warning light
    By G4orce in forum Electrical Wiring / Questions
    Last Post: 26-07-2006, 08:15 AM
  3. 'Rear light bulb failure' warning light
    By Misaprop in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-04-2006, 03:07 PM
  4. Dash Light Warning Light
    By Bongo in forum Electrical Wiring / Questions
    Last Post: 07-10-2005, 08:17 PM
  5. VZ dash fog light warning light
    By Torquative in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 14-08-2005, 07:13 PM
