Results 1 to 3 of 3
Thread: info on crank angle sensor please.
    the_jaim is offline THE JAIM
    VS series 1
    Jan 2009
    Edgewater
    Default info on crank angle sensor please.
    Gday guys
    I have a 95 Vs series 1,
    the crank angle sensor went recently I had it replaced and it went again 4 days later.
    Im just wondering if it is an on going problem once it goes the first time?
    any info would be greatly appreciated.
    MY08 Subaru Liberty GT-B & VS Exec
    Dec 2005
    Glen Waverley VIC
    Quote Originally Posted by the_jaim View Post
    Gday guys
    Did you replace it with a brand new unit? If not, then most likely that is the problem.
    If the unit was new, then there is a high chance that the interrupter blades on the back of the harmonic balancer have damaged the sensor, so I'd be checking out the back of the balancer to see if anything is amiss.
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    Did you remove the balancer to fit the new one (if it was new)
    If it was new then you may have a short in the wiring somewhere, have you checked the fault codes.
    HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
    VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
  1. Crank angle sensor?
    By sportyclansman in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-09-2008, 01:10 AM
  2. Crank angle sensor VS to VY
    By glowworm in forum Parts And Other Items For Sale
    Last Post: 09-09-2007, 05:52 PM
  3. crank angle sensor
    By play in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-07-2005, 11:19 PM
  4. Crank Angle Sensor
    By angelstar in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-04-2004, 06:21 PM
  5. Crank Angle Sensor Wh
    By kevinz in forum Electrical Wiring / Questions
    Last Post: 09-02-2004, 08:38 PM
