Results 1 to 10 of 10
Thread: VS VT engine difference
    nvo
    nvo is offline
    Jan 2009
    Default VS VT engine difference
    Just about to source and engine from either a VS or a VT or perhaps a a VX.I am going to use it in nissan navara but the conversion guys told me that it is better to use a VS engine because if I use a VT or a VX I will have to cut into my firewall.I was under the impression that the engines in question were all the same apart from internal differences.Am I wrong?
    regards andrew
    kidmavric's Avatar
    kidmavric is offline OVRKILL
    VR dumped on 20's
    Mar 2008
    a VT or VX motor would fit just as same as a VS one
    WTB: VR/VS SS bodykit
    nvo
    nvo is offline
    Jan 2009
    nvo
    nvo is offline
    Jan 2009
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    The differences between a vs and vt/x motor are very minor and are limited to things like a slightly different plenum, inlet manifold, fuel rail and injectors. As for the physical size/dimensions of the motors there is no difference.
    VS Calais
    Apr 2005
    Not sure about the vt, but vx had the EGR pipes and crap that might get in the way. IIRC when doing an engine conversion you need to meet the standards of the newest part (engine/shell), so technically you would need to keep the EGR stuff to pass with a newer engine. This may be completely irrelivant however :P
    Surely the conversion guys can give you a bit more detail why they like the vs engine...?
    VS 3.8l Exec
    May 2006
    Ya mums house!!!
    smaller transmission possibly?
    slightly different in dimension between VS to VX models...
    undar8ed1's Avatar
    undar8ed1 is offline Rags 2 riches!
    2 VXII V8 dailys
    Feb 2008
    regional W.A
    I`d say that they may have got confused and thought of the V8`s 5litre vs the LS1 what differences on size etc. they have I`m not sure but yer whatever.
    undar8ed1's Avatar
    2 VXII V8 dailys
    Feb 2008
    regional W.A
    VX SS M6
    Jun 2005
    vt vx trans bell housing are bigger thats the only thing really
  1. Engine difference?
    By SV6er in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 30-10-2008, 04:12 PM
  2. Difference between series 2 vn and vp engine?
    By evl-304 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-05-2008, 11:43 PM
  3. VN engine difference? series 1 and 2?
    By beareatsfrogs in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-04-2007, 06:11 PM
  4. Whats the difference between a series 1 and a series 2 engine???
    By VQXTC in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-09-2006, 08:56 PM
  5. Can memcals make a difference on a stock engine?
    By greenfoam in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-11-2005, 01:25 PM
