Results 1 to 6 of 6
Thread: Vr Oil Leak
    Vr S2 Calais
    Jan 2009
    Default Vr Oil Leak
    Hi all im new and am after some info
    My car has been leaking Trans/powersteering fluid it only leaks when i have been running the vehicle and turn it off i had it checked and they said something about an oil stain on the speedo transducer i dont know where that is located but am wondering what else would do it also when i drove at 100kmh or over the engine light comes on why is that cheers all for any help
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Check your trans fluid level as it may be low which could cause the engine light to come on (hopefully as otherwise it could be expensive). Also have a look under the car to locate exactly where the leak is...if they said there is a stain on the speedo transducer I think on the VR its towards the rear of the trans.
    And welcome.
    Vr S2 Calais
    Jan 2009
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Vr S2 Calais
    Jan 2009
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Colour of the oil - not red like trans fluid. You really need to degrease the rear of the engine to make sure the leak is not coming from a rocker cover.
  1. about that oil leak..
    By aella in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-12-2008, 09:00 PM
  2. oil leak
    By Black.Label in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-03-2008, 10:16 PM
  3. VS V6 oil leak
    By mcvk in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-12-2007, 03:34 PM
  4. Oil leak
    By boojak87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-08-2007, 11:48 AM
  5. Vn Leak!!!! Help
    By spacattack in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-02-2007, 08:05 AM
