hey guys
just wondering how to remove the 2 straps on the bottom of the fuel tank on my vr v6 exec
cheers jordan
From memory you just remove the bolt from the rear of each strap and then it just swings down like it's hinged. Jack the tank up first of course using some wood to protect the tank. If you are removing the tank it is best done when empty.
MY RIDE
^^^ That's correct, you will also need to unplug any pipes if you wish to move the tank, the pipes are very short...
