Results 1 to 4 of 4
Thread: diff question
    Haydz's Avatar
    Haydz is online now 346 cu/in
    VS UTE LS1 T56
    Nov 2007
    Liverpool.Sydney,NSW
    Default diff question
    hey guys just wondering a few things for an lsd.
    1. will i have to change the pin thingo. the one that hooks up to the diff centre?
    2. the shims and bearing carriers? are they the same from single spinner to lsd?
    and lsd oil any reccommendations?
    or any special oil people run for a spooled diff?
    padrickz88's Avatar
    padrickz88 is offline Rick =]
    VN V6, nothing special
    Dec 2005
    sunshine, melbourne
    only 1 i can answer is you dont need any special oil for a spooled diff, just the single spinner stuff
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    a spooled diff and a lsd are 2 diffrent things lsd will reguire a diffrent oil spooled diff will not
    and no unless its worn or you are changing the ratio
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    When you say "pin thingo" do you mean the pinion gear? If so then no you dont have to change it as long as you swap the crown wheel over from you single spinner centre to the new lsd centre so that you keep your original crown wheel and pinion together as a mated pair and dont mix them around. The shims for a single spinner and lsd are physically the same, however may be different between different diffs, i.e slightly thicker or thinner from the factory to get the correct mesh between the gears. As a good start that will be fairly close to the mark, when you install the new lsd centre do it with the shims it was previously installed with and on the same side of the centre too as they will likely be a diferent thickness to each other. Also as a general guide, when you remove the diff cover plate, grab hold of your crown wheel and push it up and down as hard as you can to feel the knock and backlash between the gear mesh and take note of this as you want have the same amount when you fit the new lsd centre. The tapered roller diff centre bearings between lsd and single spinner are the same on a live axle diff. Most diff oils on the market are pretty good so alot may come down to your budget/preference of a particular brand but make sure it is specifically for limited slip diffs. Personally I run all Penrite oils in my car and am using LimSlip90 in my diff with no complaints. If the diff is a little worn a thicker grade of oil may help to quieten it down a bit.
  1. question about diff gears in a irs diff vs 5.0l
    By mr_clubby96 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-11-2008, 04:21 PM
  2. Diff question
    By skobs in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-10-2007, 10:54 PM
  3. VT diff question
    By nicko in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-10-2007, 02:52 PM
  4. Diff Question
    By Phantom VK in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 24-04-2007, 05:49 PM
  5. VS diff question
    By Fiza in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-04-2006, 08:28 PM
