Results 1 to 5 of 5
Thread: How do I get the heater hose fitting out of the back of the inlet manifold?
    VR Executive S1
    Mar 2008
    Default How do I get the heater hose fitting out of the back of the inlet manifold?
    I've got a 1994 VR V6 Series 1 on LPG. Have just found a broken heater hose fitting at the back of the inlet manifold. There's a bolt next to the fitting that I've taken out, but the remainder of the fitting still won't come out. Any suggestions? I don't wanna go gluing the broken-off piece back onto the rest of the fitting, 'cos I can see it breaking off again, and I doubt that there's enough of the fitting left to simply re-connect the heater hose to that.
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    its a bad job but it can be done
    you have to smash it up and drag it out piece bye piece, its a long job expecily on the rear but it must be done.
    on the other hand you might be able to pry it out full but unlikley.
    also i have found you can get stainless stel ones of these fittings now, cost a bit more but will last longer than the plastic ones....
    VR 3.8L
    Jul 2008
    I had the same problem the other week and after breaking the other similar piece on the front i decided it was easier to take of the manifold.Used the same gasket saved $50. Pocketed the bit from the wreckers cost me $1 entry.Bit of stuffing around but fairly simple.Works fine now
    moff_man's Avatar
    Nov 2008
    Quote Originally Posted by mick1979 View Post
    you might want to keep an eye on thoes gaskets. there not ment to be used again.
    VR 3.8L
    Jul 2008
    so far no problems.Just need it to last a couple more months
  1. Inlet manifold... DOH!
    By VNCalais98K in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-11-2011, 04:46 AM
  2. vs inlet manifold
    By jas98 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-02-2008, 12:49 AM
  3. inlet manifold
    By ab56452001 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-01-2007, 09:52 PM
  4. Inlet manifold-exhaust manifold cracked
    By aussieghostrider in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-06-2006, 10:23 PM
  5. inlet manifold
    By madsav in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-08-2005, 04:19 PM
