Hi there,
Anyone knows what are the tech specs for the alternators that are originally mounted on the VS?
Is it possible to get a bigger one that produces more amps?
Saving above 40% of fuel with my Hydrogen on board generator.
Not sure of the specs, but yes you can get a better onesorry I couldn't help with the full question
EDIT: Apparently it's 100 amps with nothing running, depending on how much bigger you want your looking at a fair wack of $$$
And your best option would probably be to put a bigger battery in...
Where do you get them
50 amps will do widely. Any online shop supplying that kind of gear? What kind of price am I looking at?
Thanks. Now anyone knows the power output feed of the original alternator on a vs?
The factory fitted BOSCH alternator for the VS V6 is rated at 90A. I don't think this was ever really enough to begin with, as many of you would know, you only need to have the airconditioning and headlights on and things begin to dim, especially when you have got your indicators on too. The VT V6 had a 100A alternator, so I would imagine that this would just bolt straight up.
also the police/ emergency vehicle ones have a bigger one again. 110amp i think
If the light system starts to dim when the alternator is overdrawn with a 90A then 110A will not do that much better I reckon. I'll ask my auto electrician. Cheers.
