hey guys. when i take off quickly say half to 3 quarters throttle i get this sound as if the tyre is rubbing on the gaurd or something. it sounds as if it is coming from the front passenger side. could also be the rear.
anything i should check any bushes etc that i can check to see if they are causing this problem thanks alot.
failing anyones reccomendations being right ill take it to pedders and get them to check everything out and tell me what it is
thanks again guys any recommendations welcome and ill check out the bushes or what not.
It may be an exhaust leak from the manifold gasket or somewhere along the exhaust. Be prepared for a big list of faulty components if you ask Pedders as they adopt the 'scattergun' principle.
i would say lower control arm bushes but this is a dignostic from a computer screen.......it might be wise to take pedders up on there 52 point safty check or how ever many points they check.....
at least than you can make the decission if you want to fix it or not
hmm yeah i think ill go to pedders.
see what they say is wrong with it. then take it home and check out all the parts they say are worn. to see if they would cause problems
