Results 1 to 3 of 3
Thread: VR Berlina BCM Fault Maybe?
    vl berline wagon
    Jan 2009
    Default VR Berlina BCM Fault Maybe?
    Hi,
    My partner came home complaining the car drivers window would not go up. I got on here and found out how to bypass everything to put it up. Now I notice that the central locking doesnt work at all.
    I suspect that its the bcm. The other windows wind fine.
    So does this sound like its the bcm? If so ... where is it located in the car so I can replace it.
    This is a berlina station wagon 1995.
    Thanks for your help in advance.
    C
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    its not the bcm, if it was it would be locked and the car would not start, try replacing the switch for the window or even looking at the wiring to the door
    vl berline wagon
    Jan 2009
    Thanks for your answer...
    Could it be a faulty bcm?
    The security system is now dead as well I just noticed and in the recent past the cruise control would work intermittently.
    ...and curiously the rear demister light is on permanently.
    C
  1. VS Berlina SRS fault
    By glenneaux in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-05-2008, 07:14 PM
  2. Is this VP fault, V6 fault or just bad luck?
    By MyVPIsFasterThanYourVP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-12-2006, 10:46 PM
  3. Replies: 57
    Last Post: 12-10-2006, 08:47 AM
  4. vy berlina - door light and alarm fault
    By natandwade in forum VY Holden Commodore (2002 - 2004)
    Last Post: 28-04-2006, 08:59 PM
  5. Fault light came on but reports no fault
    By VRBerlina05 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-08-2005, 07:21 PM
Tags for this Thread
