Results 1 to 15 of 15
Thread: vr wont crank over
    vr wagon, vx executive
    Jan 2005
    Default vr wont crank over
    i perchased a vr series 2 wagon had no power and will not crank over. got it cheap. battery had 4v charged it up out of the car and now has 12.8v. ingnition now lights up, central locking now works,turn the ingnition on and the engine fan works go to start the car and i hear a click from the fuse box in the engine bay but wont crank. test light has power to starter. error code 12 and 31. security light on consel does not light up and warning light on speed alert doesn't light up. i think 31 is no signal from BCM to ECU. should i change the BCM or give something else a go?i am using a vt manual as a reference but i don't know if the wiring diagrams are the same to check voltage at ECU from BCM. it says check 3-5v at A3 RB wire but on my vr RB wire is not in A3 plug but RB wire does have 5.06V. A3 has 0.
    is it my BCM?
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    more than likley the key.....if you replace the bcm you have the replace the key head anyways so its a much of a much ness
    Jan 2005
    was my wiring check correct? if i replace the key do i have to replace the BCM as well?
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    You can replace only the key but you have to get it coded to the BCM. Have a look at the wire ring around the ignition. Bend it out a bit so it contacts the key all the way around when the key is turned. But it does sound like the battery in the key is flat.
    Visit my Facebook page
    moff_man's Avatar
    Nov 2008
    Quote Originally Posted by Not_An_Abba_Fan View Post
    the battery in the key will not effict the immobilser part of the key.
    also check for a clean key, just undo the 2 screws and remove the stalk and give it a clean.
    the immo uses the stalk of the key (the cut bit) as an earth if this is dirty than you will get no go
    but yes check the key reader and also check the detent switch (park netural switch) my park switch is playing up at the moment and will not allow me to crank sometimes also the immobliser system seems to be working too good in my car because sometimes i need to remove the key fully and start again sometimes due to this fact.
    as for the bcm dignostics im not shure.......
    Jan 2005
    the ring is getting a good contact with the key it pushes the ring in about a mm all turn
    Jan 2005
    moving the tbar makes no difference at all forward back left or right still no go
    Jan 2005
    i just did another check and the remote is unlocking the car and locking it and the centre consel sercuity light is working with the remote. doesn't flash when cars is unlocked but does flash when locked
    moff_man's Avatar
    Nov 2008
    try starting it in netural and see what happins, it still could be the park netural switch.
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    Jan 2005
    netural makes no difference, change the starter relay but still no go. put a screw driver across the starter today. heard a click at the relay box but not at the starter so i will fit another working starter and try again.
    VR Acclaim
    Sep 2008
    Kingsley WA
    Can you borrow another battery, or get a jump start from another car? I'm not sure, but the fact that the battery is putting out 12.8 Volts may not necessarily mean it has enough grunt to crank the engine.
    Jan 2005
    i have tried a jump as well but it is still only a click from the relay box when you turn the key . the motor doesn't move. but you can turn it with a shifter on the pully and hear comprestion in the motor so i know the motor is not seized. i will fit starter motor tues arvo and let you all know thanks.
    Jan 2005
    i fitted the second hand starter motor today and it fired up first go. fixed for $20
  15. #15
    The1's Avatar
    Jan 2005
    Toowoomba QLD
    hehe awesome, bet your happy now.
  1. VX wont crank over
    By Mr Szu in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-12-2008, 01:01 PM
  2. vr wont crank over
    By back_in_a_vr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-03-2007, 11:56 AM
  3. VN V8 Wont Crank over when Hot
    By madA69 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-01-2006, 11:42 AM
  4. engine wont crank
    By Michaelgreenaway in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-04-2005, 11:23 AM
