Results 1 to 5 of 5
Thread: how do u take of the pully which loosen the belt???
    vs ss commodore pantha mica
    Jan 2008
    bacchus marsh vic
    Default how do u take of the pully which loosen the belt???
    hey need to get the pully off which causes the belt to become loose can u plz tell me how to get it off ??? cheers
    VY SS
    Jun 2006
    Albany
    you need to get a ratchet or spanner on the tensioner and turn it anti clockwise which will loosen the belt so you can take it off
    Jan 2008
    bacchus marsh vic
    sorry i meant really i need to take off the tensioner , all together need top get to bolt behind the tensioner, a seal into the engine where water goes is leeking need to replace o ring, the part is next to water pump and behind tensioner,. not enought room for spanner or rachet and can only get this bolt off if tensioner comes off
    VZ SV6
    Oct 2008
    Newcastle NSW
    It's a right hand thread, turn it clockwise to undo it. You might need something a bit longer than a normal ratchet though
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    yes clockwise to undo, but its left hand thread
LinkBacks (?)
  1. 01-03-2011, 05:26 PM
  2. 23-02-2011, 10:13 AM
  3. 04-12-2010, 10:32 AM
  4. 01-12-2010, 01:20 PM
  5. 30-11-2010, 07:00 PM
  6. 21-11-2010, 05:18 AM
  7. 08-11-2010, 05:54 AM
  8. 29-10-2010, 03:07 PM
  1. who knows a good place in WA to loosen a stally from 3250 to 4000rpm
    By VYBR8R in forum VY Holden Commodore (2002 - 2004)
    Last Post: 21-01-2009, 08:58 PM
  2. Nut wont tighten or loosen??
    By wrx884 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-05-2007, 08:18 PM
  3. Belt Pully bearings
    By chevy_big_block_bro in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-02-2007, 07:20 PM
  4. Belt Tensioner Pully VS COMMODORE
    By marinello red in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-07-2006, 10:49 AM
  5. Replacing SC14 stock pully with an alternator pully ?
    By gemini in forum General Discussion
    Last Post: 08-05-2006, 04:02 PM
