Results 1 to 8 of 8
Thread: Reverse drops in hard
    VZ Berlina
    Jan 2009
    Maitland SA
    Default Reverse drops in hard
    when the car has been driven for a little while if i drop it into reverse it drops in hard with a clunk, does anyone know what the problem could be?
    VS V6 Acclaim
    Jul 2008
    undar8ed1's Avatar
    undar8ed1 is offline Rags 2 riches!
    2 VXII V8 dailys
    Feb 2008
    regional W.A
    ECU or chip problem try reseting your computer by taking out the engine fuse located in the engine bay for 30 secs then replace and try it, may help!
    System's Avatar
    System is offline Control is a way of life
    2005 VZ commodore exec
    Oct 2007
    i have the same thing, every time i put it in reverse, the revs drop then a small 'clunk' is heard- and yes my uni joint needs work too, so that could be ur problem
    Unions: the people who brought you weekends
    ryno_vrx's Avatar
    ryno_vrx is offline Donating Member
    VR HSV enhanced Berlina
    Nov 2008
    Mirani
    Quote Originally Posted by System View Post
    yeah mines the same but i've really only noticed it after i replaced my diff so i was guessing it had something to do with that, but i honestly wouldnt know
    VZ Berlina
    Jan 2009
    Maitland SA
    Quote Originally Posted by BowTie View Post
    Yes. It sounds like the uni-joints in your tailshaft.
    is that bad?
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    Quote Originally Posted by ufo8mycow View Post
    is that bad?
    not really.
    uni-joints are about $30 from an auto shop and easy as to remove/install.
    search the "how to" section and there should be a writeup on how to replace a uni-joint
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    Quote Originally Posted by whiteknightVR94 View Post
    please explain how it could be that?
  1. Installing hard top, hard lid or hard cover?
    By clapnrobem in forum General
    Last Post: 12-10-2011, 08:36 PM
  2. drops out of 5th
    By Uber_Matt in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-09-2007, 12:06 AM
  3. it drops revs...
    By commod8 in forum General
    Last Post: 22-02-2007, 07:01 PM
  4. VN drops back a gear when speedo drops out
    By V8commodore_chick in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-11-2006, 12:18 AM
  5. V8 Power Drops
    By neo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-08-2006, 10:53 PM
