Results 1 to 12 of 12
Thread: Sway bars thickness
    vr commodore executive
    Jan 2009
    Default Sway bars thickness
    Hey,
    I have 225/60/16's on my VR, and i want to know what the size of the sway bars would need to be for a good upgrade in handling. I was thinking 27mm front and 20mm rear? any opinions?
    Is is too thick or too thin, i was tossing up between 18mm and 20mm rear bars
    Jun 2005
    mines 28mm. might be a HSV thing, as its a lot thicker than whats on my VN. seems to handle well with that
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    For a sedan, the 27mm front and 20mm rear you mentioned should be fine, a good upgrade from stock.
    27mm fronts only came on HSV's(also 28mm) or aftermarket, peddars, Kmac, Whiteline etc.
    If you don't have any new bars as yet try the wreckers.
    This option from the wreckers would be a lot cheaper than buying new.
    VR/VS wagons ran a 26mm front bar (sedans 24mm) and plenty of commodores ran 18
    mm rears (20mm rears only came on VN police cars).
    SW
    HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
    VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
    Cammed mafless VS Calais 5-speed.
    Dec 2008
    Dec 2008
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    Quote Originally Posted by maldotcom2 View Post
    Is 26mm on the back of a sedan too big?
    26mm on the rear is way too big.
    Biggest aftermarket bar I've seen is 22mm and biggest factory bar is 20mm.
    SW
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    are the larger sway bars actually any good? i have a white line front bar in my parts
    VY SS
    Jun 2006
    Albany
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Feel how your car handles, and judge what you need accordingly.
    When speaking relatively to changes in the opposing bar:
    Thicker back = more oversteer, thinner back = more understeer
    Thicker front = more understeer, thinner front = more oversteer
    The 1972 HQ Kingswood
    Dec 2008
    Quote Originally Posted by Surfwagon View Post
    SW
    Ok. My rear bar is already 19mm. Is that standard for a VS?
    Set of thongs
    Dec 2005
    Stonedville
    Quote Originally Posted by Morton View Post
    hmm mine just has ****ed camber and alignment
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    Couldn't tell you, usually around 16 0r 18mm but 19mm not bad size just play with your front for now.
  1. FE2 Sway Bars
    By mulligan-can in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-03-2007, 12:08 AM
  2. sway bars
    By HVXII in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-10-2006, 01:59 PM
  3. Which Sway bars
    By proto_vr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-08-2006, 01:52 PM
  4. Sway Bars
    By MBS206 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-05-2006, 11:14 PM
  5. Sway Bars
    By Rocky1 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 27-11-2005, 08:11 PM
