Results 1 to 15 of 15
Thread: Stock 5 'vs' Senator 215i
    VS 5L
    Jan 2009
    Default Stock 5 'vs' Senator 215i
    Hey all, i just joined this site. I love VS's and had a few. Mainly utes. I want ti buy a VS 5L Spack 98-00 series 3. Cant afford or find a good SS or Maloo. So i'll go the 5liter Spack. Now i want to rebuild a stock 5 to the HSV Senator's 215i standard. Searched everywere to find engine stats. Like cams, pistons, heads etc. Found nothing!
    I want a tough, strong, un stroked engine. The 215 output or there abouts is good enough for me. Any good advice would be great. Any new mates around the Fremantle WA area would be sweet to.
    Cheers Aj
    VU SS UTE / 5 Litre Volvo /Trusty Swift
    May 2008
    Penrith NSW
    I maybe wrong but I'm sure the 215i was a stroked 5L..
    Why is it called Alcoholics Anonymous when the first thing you do is stand up and say, 'My name is Ray, and I am an alcoholic'?
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    undar8ed1's Avatar
    undar8ed1 is offline Rags 2 riches!
    2 VXII V8 dailys
    Feb 2008
    regional W.A
    the only way to get that power without opening the engine up is, CAI (cold air intake) K&N high flow panel filter extractors decent exhaust set up and a foamy (greanfoam) tune to suit. Some diff gears a covette servo and a hi-flow cat will also help things. with everything else kept good and fresh like plugs leads etc... then you will net 200kw+.
    undar8ed1's Avatar
    2 VXII V8 dailys
    Feb 2008
    regional W.A
    Quote Originally Posted by DVOLVO View Post
    yes it was.. and you may also like to know that in the Series 1 VT`s they had a 220kw stroker for the top of the line HSV`s (GTS/senator) then a couple of years later you could by a 220kw berlina in the form of a LS1, lol the change was wild.
    VS Berlina 3.8
    Dec 2008
    Quote Originally Posted by VSjunkie View Post
    Umm.. there's no such thing as a 5L S-Pack. The 5L S-Pack is an SS.
    S = v6
    SS = v8
    Also, just out of curiosity, why no stroke? Do you not want to rebuild the bottom end?
    Wagon_Wheel's Avatar
    Wagon_Wheel is offline Drop A Patch....
    Aug 2005
    Mt Martha, Vic
    Actually your wrong, there was a few 5litre S-packs.
    In the series 1 and 2 VS UTES only, they didnt have the SS ute until series 3 im pretty sure, so they had the 5ltr as an option on the Spack utes.
    And yes the 215i are a harrop stroker, and arent the best out there, if you were going to stroke your motor you would want something better than the factory style setup.
    VS Berlina 3.8
    Dec 2008
    Quote Originally Posted by Wagon_Wheel View Post
    Wow, learn something new everyday.
    VP Executive R-spec
    Jan 2005
    The Factory strocker is pretty good, they can make around about 190-200rwkw with nothing more than some extra timing and run 13's
    VZ Calais
    Aug 2005
    Mackay Qld
    undar8ed1's Avatar
    2 VXII V8 dailys
    Feb 2008
    regional W.A
    Yep seen those, funny to see but still that (motor) was the only difference
    between the S and the SS.
    F.Y.I the series 3 SS utes have the VT SS "commodoreSS" stickers/decals and VT SS(blue) seats.
    VS Clubsport series I, VY II R8 Clubsport
    Jan 2008
    Sunbury, Victoria
    Quote Originally Posted by _R_J_K_ View Post
    S = v6
    SS = v8
    My father in law had a series II VS, S-Pack ute with 5 Litre fitted factory.
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Yep series 1 VS atleast had 5ltr S pak. I know because my mate had one, was auto though.
    But as per OP, the 215 engine was definatly stroked.
    Reaper
    betts's Avatar
    betts is offline Double banger
    Built toyota surpa
    Nov 2005
    Just around the corner
    S = v6
    SS = v8
    I own one mate
  15. #15
    shanhsv's Avatar
    shanhsv is offline Luvo
    VS Berlina V8 5speed
    May 2005
    Muswellbrook,NSW
    And if you dont want to stroke the motor,C.O.M.E. racing have a 215kw kit,all it is,cam chip and lifters for $1000.With a decent zorst and air intake set up,ohh and talk to greenfoam about a tune,ur looking at a fairly faster ride
    WTB:VR/S HSV 250km/h speedo cluster
  1. MY 94 VR 215i SENATOR
    By sir355 in forum VR - VS
    Last Post: 26-02-2012, 09:48 AM
  2. VYII HSV Senator Stock Airbox
    By Senator Slash in forum VY Holden Commodore (2002 - 2004)
    Last Post: 26-01-2009, 08:23 PM
  3. VR Senator Stock or Modified?
    By Galixia in forum General Discussion
    Last Post: 09-06-2008, 01:17 PM
  4. wtb: 2500 / 2800 stall converter for vr senator 215i
    By petezor in forum Swap / Wanted to Buy / Trade
    Last Post: 12-09-2007, 09:23 AM
