Results 1 to 4 of 4
Thread: Quicky: VR V6 / VS V6 Clusters identical?
    VS Commodore Omega
    Apr 2005
    Default Quicky: VR V6 / VS V6 Clusters identical?
    Hey all,
    Trying to source a cluster (level 2 or 3), just wanting to know if the VR and VS clusters are the same connection-wise (plug and play) or the looms/lights are slightly different? I notice all of the clusters on eBay are for VR/VS but I thought I read they were different?
    Thanks
    dufus is offline Donating Member
    rickshaw
    Jun 2006
    Yep VR/VS clusters are the same, as are VN/VP clusters but the two are not interchangeable with each other. So you can use a VR cluster in a VS and vice versa.
    Fekason is offline Fekason
    MY11 VE Series II SV6 Manual
    Mar 2005
    Penrith NSW
    Default Check the green printed circuit sheet!
    As aleardy advised, VR and VS are interchangable. VN/VP will plug in, but have a different circuit, so smoke will appear if the wrong one is used.
    If buying a VR/VS cluster, make sure that the green printed circuit sheet is in OK condition. It is not uncommon for stored clusted to wear away a circuit or two, so be cautious.
    VS Commodore Omega
    Apr 2005
    Thanks for the advice guys, helps out a lot... and I know about those damned printed ribbon cables, that's why I need a new cluster. Rep+ for you both
  1. VR-VS Identical panels???
    By gontix in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-05-2008, 03:18 PM
  2. vk dash clusters
    By NOT.BT1 in forum Parts And Other Items For Sale
    Last Post: 22-10-2007, 05:56 PM
  3. x3 level2 clusters
    By chopsy in forum Parts And Other Items For Sale
    Last Post: 07-10-2006, 03:24 AM
  4. Swapping clusters on VY
    By Wagone in forum Electrical Wiring / Questions
    Last Post: 12-09-2006, 11:23 PM
  5. A quicky
    By The1985divo in forum Jokes/Humour
    Last Post: 30-08-2004, 10:22 PM
