Page 1 of 2 12 LastLast
Results 1 to 25 of 35
Thread: How much oil is too much?
    vs 96 acclaim
    Nov 2007
    Default How much oil is too much?
    As stated i'm just wondering how much oil is too much..mines around 5-7mm above the full mark and just wondering if i should leave it be (as i don't really want to get under the car again) or is it something that i should be rectifying immediately? cheers
    VS executive
    Jan 2009
    I have 2 cars VZ sv8 6 litre and VU ute 5.7 litre
    Sep 2008
    VZ AWD One Tonner
    Jul 2006
    Yep, don't ever fill above full as some cranks use a particular level of oil to throw oil up into the block. By having it too full it won't throw oil up. It has a 'max' for a reason... best to fix it unfortunately.
    - GSL RallySport - Ph: 1300 884 836 -
    Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
    - QFM Performance Brake Pads -
    Also specialising in
    - DMS High Performance Shock Absorbers - Monit Rally Computers -
    DannyboyDS is offline Just hand me the pliers.
    VS Berlina
    Feb 2007
    the distance from full to the "top up" mark on the stick is about one litre, so use that as a reference and think about the above post.
    Haydz's Avatar
    Haydz is online now 346 cu/in
    VS UTE LS1 T56
    Nov 2007
    Liverpool.Sydney,NSW
    this reminds me about when my cousing called saying she filled her barina up with oil. till it was full..
    and she said she started it and it was making funny noises.
    after a few questions i found out she had filled it up to the filler hole. using almost a whole 5 litre drum and it still had enough oil she just opened the cap and went ahh there is no oil ..
    thats women for ya.
    but yeah your better off draining it and putting the right amount in just to be safe
    dufus is offline Donating Member
    rickshaw
    Jun 2006
    Too much oil can be just as bad as no oil, defiantly drain some out to reach the correct level.
    vs 96 acclaim
    Nov 2007
    appreciate the help guys..i'm assuming the easiest way to fix this is by emptying out the filter? please correct me if there is an easier way
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    undo the sump plug minimally and it should let some out, or undo it and hold the plug against the hole and let some out that way.
    Just DONT do it when the engines HOT
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    mate who had a VS when new said the dealer told him to always fill it 5mm above the full mark ... ? said it helps for something. anyone else heard that ?
    VS Berlina
    Feb 2007
    do you do that GreenAcc?
    if you do that and have never had any issues, then i'd start doing it too :P
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by greenacc View Post
    Think about it......how would a dealer know more than the manufacturer that has their reputation on the line. Any dealership found to be issuing information which contradicts official GMH servicing directives would soon find they are no longer a GMH dealership. My opinion only.
    Haydz's Avatar
    VS UTE LS1 T56
    Nov 2007
    whenever i do an oil change i just chuck the whole 5 litres in engine just burns off the rest of the shit it dont need..
    Jun 2005
    Quote Originally Posted by Haydz View Post
    showing your intelligence as usual
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
  15. #15
    rickshaw
    Jun 2006
    Your car will last long with procedures like this.
  16. #16
    VR Acclaim
    Sep 2008
    Kingsley WA
    The 'Full' mark on the dipstick for my VR is not accurate. I measure the oil by volume and ignore the level on the dipstick as the amount it should have. 4.1 litres of oil takes it to about 8 mm above the full mark.
  17. #17
    Haydz's Avatar
    VS UTE LS1 T56
    Nov 2007
    haha.. it only goes the tinnyest bit above the full mark. so its not worth keeping the remaining couple of ml's..
    and really who gives a shit when you can get another engine for under 500 bucks.
    thats with my dipstick anyway. so thats probably why i get a wrong reading.. but who knows
  18. #18
    rickshaw
    Jun 2006
    Despite what your dipstick says you are putting close to 25% too much oil in your car, this cannot be a good thing.
    So what if a new (second hand) engine is only $500, is saving 2 minutes really worth the $500 bill, for an engine that may be worse than your current one?
  19. #19
    Haydz's Avatar
    VS UTE LS1 T56
    Nov 2007
    i guess your right with that.
    but i just looked on the dipstick and kept putting the oil in till it said full. then there was a couple hundred ml left over..
    anyone with any info on what a bit of extra oil would do to the engine being either an ecotec or a buick. would it stuff the oil pump or something else?
  20. #20
    rickshaw
    Jun 2006
    To much oil can damage seals and turn the oil to foam by aeration from the crankshaft causing insufficient lubrication of engine parts.
    Some people should not be allowed to work on cars.
  21. #21
    VP Executive R-spec
    Jan 2005
    I've allways filled mine at oil changes to the middle right between add and full, I figure there's no use wasting more oil than you need. This way I have more clean oil left over for later
  22. #22
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    vr 93 to 95 uses 4.1 L with filter
    vs 95 to 97 uses 4.3 L with filter
    vs series 3 ute 98 till 00 uses 4.8 with filter
    and mine has allways been over full bye about 1/2 L it aslo has that much nurlon stuff put through it too so meah......needs a service now i think of it
  23. #23
    VZ AWD One Tonner
    Jul 2006
    Quote Originally Posted by Dufus View Post
    ^ Correct.
  24. #24
    VP Exec
    Jun 2005
    Yes, at least sort of. The oil level (and dipstick and dipstick tube to reflect that) in V6 was revised during VS production - with no other changes. It was also done as a rework on some cars. If you had/have an early car with the early type dipstick and tube it would be OK to run (5mm??) over. Not so much with the later items installed. I suspect that this is where the info. from the dealer came from.
    It was done because some cars were using oil (some valve stem oil seal leakage and low friction = low tension oil control rings) and customers were complaining. The extra oil was to ensure that that cars would maintain a safe oil level through the specified service interval and to reduce the incidences of customer complaints because the oil level was "low" i.e. if the high and low marks on the dipstick are 1L apart, -0.5L (say) = "half full" and complaint, if they are 1.5L apart, -0.5L = "2/3 full" and still OK.
    Quote Originally Posted by greenfoam View Post
    That's how they come from the factory anyway. They are almost always topped up to full during the pre-delivery inspection though.
  25. #25
    Chirpstr's Avatar
    Chirpstr is offline A new project attack
    VR Berlina M5, VP M5
    Sep 2007
    I always top mine up never to the full mark just down from it...a little over 3/4's.
