to my knowledge the tank is a sealed unit, on the sedans it is utes im not familar with.
Empty the tank, get under the ute, disconnect all plugs and hoses, remove the 6 bolts that hold the sender unit in and rotate the unit 90 degrees so the float arm fits in the notch in the tank. remove slowly, and unplug the hose inside the tank connected to the pump. then u can remove the pump and reverse this proceedure to install.
LinkBack URL
About LinkBacks
This is my vr that I rebuilt ....
......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
