Results 1 to 5 of 5
Thread: alarm system
    vr commodore s2
    Jan 2009
    Default alarm system
    can any help my vr commodore factory fitted alarm system goes off after driving or on very hot days has any one else had this happen?
    aceventura's Avatar
    aceventura is offline Doesn't drive like this
    Mazda 6
    Oct 2008
    SEQ
    Quote Originally Posted by ivan1964 View Post
    This may or may not be helpful - I bought a VS with a factory fitted alarm, and the alarm would go off seemingly randomly (not necessarily on hot days). Strangely the interior light would also blow at the same time.
    Turned out that a wire related to the alarm that ran through the rear window pillar (on the drivers side) had the insulation worn through. I can't remember details, but it was either an earth that was shared with the interior light????? or an interior light wire was worn through at the same spot.
    Anyway I bought the car second hand at a Toyota dealership and it was still under the 3 month warranty. It took the guy all day to figure the problem out - if it wasn't under warranty I would hate to think what it would have cost!
    My guess is that you also have a wire that is worn through somewhere, but I can't help you any more than that. Is there anything else that blows, or you that you are having problems with?
    vr commodore s2
    Jan 2009
    thanks for the info ill will have a look i have an idle problem its running rough on first start up and has a slight miss untill i get up to about 40 ks it also stallsat time when the revs drop down the engine warning light was coming on i replaced the temp sensor and this has stopped the light coming on do you what the sensor at the back of the mtr controls? would be happy for any feed back thanks again for the info regards ivan
    aceventura's Avatar
    Mazda 6
    Oct 2008
    SEQ
    Rough idling according to most people is likely to be the idle air control valve (IAC valve). Pull off the throttle body and clean the pintle. Also if the throttle body looks dirty give it a clean too.
    No idea what your talking about regarding the sensor at the back of the motor. I don't have a VR, but it could be the MAP (manifold air pressure) sensor???
    Also can you use some puncuation and seperate each thought with paragraphs - It would make it much easier to read.
    seraphic06's Avatar
    seraphic06 is offline Woodgrain Nut
    VS Esteem SII Wagon
    Sep 2008
    Adelaide, SA
    Check this current thread
  1. alarm system
    By ivan1964 in forum General Discussion
    Last Post: 22-11-2011, 06:41 PM
  2. VE Alarm System!!!
    By wesker in forum VE Holden Commodore (2006 - ?)
    Last Post: 08-06-2008, 12:22 AM
  3. What is wrong with ALARM System
    By vx ss phil in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-01-2007, 10:19 PM
  4. VS Alarm system
    By CommyLover in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-07-2006, 02:20 PM
  5. Alarm System For Vs
    By Gobbles in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-03-2004, 10:31 PM
