Results 1 to 7 of 7
Thread: lowered front end questions..
    V6 VR acclaim
    Jul 2008
    Scone, NSW
    Default lowered front end questions..
    ok. i have an issue with a clunkin in the front end.
    when i bought my car i had to replace both sway bar link rods as they bent. then i had my front end lowered, just changed the spring, thats all and it was fine. now i have put actual lowered struts in and im having alot of issues with noises comin out of the front right. its ticking as i drive down the road, then it clunks under light brakes. im gonna stick my head under there again tommorow and see if it has anything to do with the brakes.
    my question is. does anyone have any idea what i should look for? is starting to **** me off.
    edit: i have noticed on another users car, a larger style of link rod that is thinker and has a bend in it. should i get some of these as well?
    edit 2: its a VR series 2 im pretty sure
    Jarrod.
    If it aint broke, dont fix it.
    NORTI's Avatar
    NORTI is offline come get me
    VR Calais 5L, WM Statesman
    May 2004
    check the top of the strut to see if the rubber/plastic in the 'cap' has perished. its a common problem, the knock under braking or when hitting a pot hole
    VR S Pack - 5 speed
    Sep 2008
    Moorebank
    when you changed your struts did the strut top fall apart and all the ball bearings fell out? lol.. coz thats what happened to me and put em all back in but it knocks and ticks and stuff now... replace your strut tops should fix it.
    V6 VR acclaim
    Jul 2008
    Scone, NSW
    ok, so it seems to be a problem coming from the assembly on top of the strut. when i hve the dosh i will replace both sides. but i will get a wheel allignment when i put the 18's back on tomorrow, if that doesnt help, then ill have to take more drastic measures. cause, yes the ball bears did fall out on me, but i repacked it.
    anyway, thanks for the help. would not have thought to look there.
    Jarrod
    VR 5.0L Caprice.
    Dec 2005
    Sorry to say, but i just can not believe you would even think about repacking the strut top bearings. They fell out becasue they are stuffed. Replace them, and do the rest of the people on the road around you a favor..
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    yeh as said teh bearing assembly and/or the top rubber mount is stuffed, when i changed me shocks in me vs when the ride height was stock i reused the bearings but when i took them off to lower teh car (about 1 month later) they broke into 1 million prices....lucky i have brand new ones sitting there ready to go in ...i got them for 20 bucks each from repco and the rubber mounts were 22 each from another place
    VT COMMODORE
    Dec 2008
    I lowered the front of my car. About 6mths later and the bearings have gone (just old, nothing to do with the suspension). Can someone tell me how to do it myself? If it is hard, I would rather pay the $250 to have it done properly.
    In regard to the question, it pays to check ALL the bushes before doing anything major. Holden put cheap ones in that dont last long.
  1. [NSW] WTB: VR-VS lowered front strut
    By bittsa in forum Swap / Wanted to Buy / Trade
    Last Post: 12-01-2009, 07:00 PM
  2. Measure: From ground to guard front and rear on your lowered VT-VX ! :)
    By VT97CALAIS in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-06-2008, 11:00 PM
  3. Can a vn be lowered?
    By diego in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-09-2007, 01:20 PM
  4. WTB rear and front lowered coil springs
    By kowan in forum Swap / Wanted to Buy / Trade
    Last Post: 16-11-2006, 08:02 PM
  5. vr ute lowered
    By EZRA in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-07-2005, 10:25 PM
