Results 1 to 6 of 6
Thread: Petrol smell
    VH Commodre
    Jan 2009
    Default Petrol smell
    after driven or just sittin in the driveway there is a strong petrol smell , have taken a look at the fuel tank and noticed on the driver side there is a small hose coming out of the petrol tank with a plug on the end of it.. little drops are leaking from the tip of the plug. .. what is the hose a release ? or a drain plug. it leaks fairly slow . if i try fix it is petrol ganna come ****ing out at me?
    social's Avatar
    social is online now Ute Finatic
    MY06 6.0L VZ Thunder(na naa na naa..)
    Nov 2008
    South Aus
    hey mate, this happens with most post 2000 cars, what happens is, because its so hot, your petrol tank heats up and the petrol expands and pressure builds up, so u lost a bit of fuel in the engine bay cos the pressure is pushing out small amounts of fuel, ul notice this after about 10mins driving in 30degrees+ weather by pulling over and opening ur petrol cap and ul heap a *PERRRSSSSCHHHHHHHH....* and the buildup will exit and you'll get a really strong smell of petrol. Hope that helps anyone also confused about that.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    You also have a breather that runs to a charcoal canister, this is supposed to absorb fumes when the fuel vapour expands and vents from the tank. As it cools, any vapour in the canister is sucked into the engine via a hose to the intake. The hose going to the canister may be blocked or kinked causing the fuel to vent out of the hose with the plug on the end of it.
    Visit my Facebook page
    DB1
    DB1 is offline
    VS series2 ute 3.8 V6
    Feb 2009
    Hi, can anyone please direct me to the above mentioned charcoal cannister and also let me know how to check if it is okay? I have a VS series 2 UTE and the smell is killing me! thanks for any help!
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Facing the engine from the front it's on the left hand side of the radiator just under the power steering fluid reservoir - black plastic with black hoses going to the top.
    ucrvme's Avatar
    ucrvme is offline [UCRVME]
    2003 Holden VY Berlina
    Mar 2009
    Melbourne, Victoria
    this seems similar to diesel engines that have a overfill pipe that allows excess diesel to spill out. would this be the same or something diffrent?
  1. petrol smell
    By skyper in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 24-11-2008, 05:22 PM
  2. petrol smell
    By Aryashahin in forum VY Holden Commodore (2002 - 2004)
    Last Post: 04-10-2008, 12:12 AM
  3. petrol smell
    By bboystyles in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-03-2008, 12:07 PM
  4. 5.0 on LPG with very strong petrol smell
    By VS Callahan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-12-2006, 01:57 PM
  5. Petrol smell in car
    By G4orce in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-11-2006, 01:19 PM
