Hi
I need help on how 2 replace the bearings in my VR the car has IRS/ABS, I have the bearing kit however need help installing them as I need 2 replace them urgently and can't afford to have them installed professionally at current.
Thank you for any help
Checked my books and they all say take it to a workshop as specialised equipment is required to disassemble the hub.....so I guess that means you need a decent press etc. Sorry I cannot help more.
Yep, unfortunately you need the proper press etc to get the old bearings out and stick the new ones in.
The old ones will be absolutely buggered... mine had to be almost smashed out, and when they did come out, the actual ball bearings fell out everywhere... right over the entire workshop floor.
There is quite a bit of labour involved too, as both the rear driveshafts need to come out and then the bearing itself, and then the whole lot has to be put back together.
