Results 1 to 9 of 9
Thread: vr climate control problems
    vr berlina
    Aug 2008
    Default vr climate control problems
    whenever i accelerate hard or the car is going up hill, and i have the climate control on a/c, it stops coming out of the top vents and comes out of the feet vents instead, until the accelerating stops when it comes back to the face vents, any ideas what is wrong or what needs to be fixed?
    Chirpstr's Avatar
    Chirpstr is offline A new project attack
    VR Berlina M5, VP M5
    Sep 2007
    As far as I know the A/C system should turn off when accelerating harder (like when you over take) to give you the most power. If your sure it's still coming out cold on your feet then maybe it's a slight vacuum leak somewhere...maybe a split in a hose.
    aceventura's Avatar
    aceventura is offline Doesn't drive like this
    Mazda 6
    Oct 2008
    SEQ
    Quote Originally Posted by vpcommo View Post
    Yep, Wavez is right - It is a vacuum leak. The most likely cause it a faulty vacuum solenoid block ($100 to replace). Otherwise there is a small one-way valve (black and white) attached to the plenum. It might be faulty. Or you could indeed have a cracked hose
    In any case there are heaps of threads on each of these, even one posted yesterday! - Do some searching and I thing you will solve your problem.
    vr calais
    Jan 2009
    sa
    hey mate the boys are right my vr calais done the same thing look up under the glovebox and you will here leak its come off
    vr berlina
    Aug 2008
    aceventura's Avatar
    Mazda 6
    Oct 2008
    SEQ
    ok cool, how much would it be to fix and where should i go to fix it?
    Go to Holden, get a vacuum solenoid block - about $104
    The is also a one way valve (at least on the VS there is) that should only by a few dollars to replace. It is black and white and will be attached to a hose near the throttle body somewhere. Make sure you put it on the right way.
    I would fit it myself - Otherwise, get your mechanic, auto electrician or air con person to do it (where are you?). But they will probably charge a fair bit to do it, and it is about 10-20 mins work. You can do it without pulling the centre console out, but it is easier to access the acrylic vacuum manifold if you do. Do a search and you will find bits and pieces of wisdom if you are going to attempt to do it yourself.
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    Holden part#92140248 solenoid vacuum cost about $130
    Also check out this thread:
    Air Conditioning Advice
    SW
    HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
    VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
    aceventura's Avatar
    Mazda 6
    Oct 2008
    SEQ
    Quote Originally Posted by Surfwagon View Post
    SW
    I paid about ~ $104 at a Holden dealership 3 weeks ago - Don't let them charge you $130.
    But do check out the thread that Surfwagon suggested.
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    Quote Originally Posted by aceventura View Post
    I paid about ~ $104 at a Holden dealership 3 weeks ago - Don't let them charge you $130..
    I paid similar but when I reported that people kept telling me that they aren't that cheap so I only quote retail price GST inclusive now.
  1. Climate control problems
    By VSSECO in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-06-2008, 08:09 AM
  2. Climate Control Problems
    By dashortman in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-12-2006, 11:21 AM
  3. VS Climate Control Problems
    By robert_buntine in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-10-2006, 03:28 PM
  4. Climate Control Problems
    By sixshooter in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-01-2006, 12:00 PM
  5. VR Climate Control problems.
    By Famine in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-12-2005, 04:50 PM
