Results 1 to 6 of 6
Thread: VR Overheating At Lights, Then Goes Down
    VR Executive
    Jan 2009
    Angry VR Overheating At Lights, Then Goes Down
    Hey, basically I just bought a VR about 4 months ago. The car has never been a problem heat wise (usually up to the second/third line) until this weather in Adelaide (40-45degree's). The thermo is now going up to half way while driving, then goes up further at the traffic lights, then goes down to half way while driving again. I know that people say its because of the heat, but that's crap. Point of fact is A GOOD CAR SHOULD NOT OVER HEAT NO MATTER WHAT WEATHER IT IS.. Could this be a seperate issue? I have checked the Coolant, that's all fine, checked the radiator, that looks fine. WHAT ELSE? I've never owned a VR before, only VL's.
    LightningVP is offline Donating Member
    None
    Sep 2008
    Could be a few things mate, mine tends to heat up a bit as well, not sure why. But circulation of coolant could be bad (something stuck somewhere along the lines and coolant isn't flowing properly). Your thermostat could also be broken, maybe one of your sensors...
    As for the hot weather thing....I went driving the other day while it was 40+ deg outside, car was sitting above half way the whole time....went for a drive that night and it didn't pass 1/4....So yes the eat can have part on how hot the car gets...
    None
    Aug 2005
    Adelaide, SA
    VS Executive S2
    Jan 2008
    hi there,
    had the same problem with mine, although I have a new engine in mine and I worked out it is just the thermo fan kicks in really late for when the guage shows 3/4 hot. I know this cause when I got the car back with new engine in they forgot to hook up the thermo fan and I've tested it out several times after checking all the coolant radiator and everything else.
    When in the car sitting in traffic at the lights you can also noticeably hear (turn off stereo) the fan kick in and start to drop down the temp. The other thing I did was move the number plate up 40millimetres cause it's just hanging infront where it shouldnt be.
    works for me
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    my vr sits on 1/2 around town and goes up to 3/4 at a stop, it also has only been doing it since the temp has been 40 - 50 deg (deniliquin tep on friday was 49 deg was ment to get to 46 but still)
    VR S Pack - 5 speed
    Sep 2008
    Moorebank
    have you checked if your thermofan is turning on? if its not that would explain why its getting hot when you arent moving as no air is being circulated through the radiator.. is your radiator clogged up with bugs and dirt and shit off the road?.. is your thermostat opening up?.. does the engine have the right amount of oil in it?.. more friction causes more heat.. and the oil actually helps dissapate the heat too..
    a few things for you to check.
  1. vn still overheating
    By Pimpn1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-12-2008, 02:58 PM
  2. VX Overheating
    By TVR-190 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-09-2008, 02:20 PM
  3. VR overheating
    By spiderbite in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-01-2008, 07:49 PM
  4. V S overheating
    By Johnno.o in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-11-2007, 01:27 PM
  5. STILL overheating
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-12-2006, 04:16 PM
