Results 1 to 7 of 7
Thread: Oil seal under harmonic balancer (quick reply plz)
    VR Executive S 3.8
    Oct 2007
    Exclamation Oil seal under harmonic balancer (quick reply plz)
    How the hell do u get this thing off? I can see some sorta blue glue or something on there. I've pried of the outer edge of the seal with a screwdriver but the thing just isnt budgin...
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    The normal way is just to use a flat blade screwdriver....or bend a piece of flat steel to get behind it being careful not to bust the housing. The blue stuff is just Permatex sealant. Another way is to knock the outer metal shell inwards with a centre punch - just a little around the edge breaks the seal and loosens it. Good luck.
    VR Executive S 3.8
    Oct 2007
    96 vs wagon
    Oct 2010
    tas
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    holden have a special pull tool to get it out normally it has a big hook on it, but we'l never get one of those so as above! Mangle it! lol
    VR Executive S 3.8
    Oct 2007
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    As above its a round seal with steel shell that taps into a hole in the timing cover. Cost about $15-20
    After my first one shredded i was told to fill the lips with grease before fitting the harmonic balancer. That worked a treat.
  1. harmonic balancer
    By tre4 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-10-2010, 06:42 PM
  2. harmonic balancer
    By bazza250 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-05-2008, 11:42 PM
  3. Throttly body!! Need quick reply!!
    By AttaBoy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-01-2007, 01:35 PM
  4. exhaust question...quick reply needed
    By down_with_the_system in forum General
    Last Post: 16-04-2006, 10:25 PM
  5. probably a harmonic balancer
    By mickah in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-06-2005, 04:38 PM
