Results 1 to 5 of 5
Thread: speedo and temp gauge problems
    VR Exec
    Dec 2008
    Penrith, Sydney
    Unhappy speedo and temp gauge problems
    hey everyone my speedo does'nt work and neither does my temp guage on my 95 VS SS i was just wondering how to fix it was wondering if anyone has had this problem and is it a common problem?
    MY08 Subaru Liberty GT-B & VS Exec
    Dec 2005
    Glen Waverley VIC
    Quote Originally Posted by Chief VR View Post
    The speedo is electronically operated, so I'd be checking the VSS (Vehicle speed sensor) from memory it is attached to the gearbox or transmission.
    Regarding the temperature gauge, it sounds like the SENDER is faulty. If you have a look under the bonnet, follow the top radiator hose to where it joins the engine block. Just under the thermostat outlet there should be a little brass coloured 'knob' which should have a black rectangular plug attached to it. This is the temperature sender for the guage, so check that it is connected properly, and failing that you can replace the brass sensor bit, its only $8 from Holden for the genuine part.
    Hope this helps!
    DannyboyDS is offline Just hand me the pliers.
    VS Berlina
    Feb 2007
    do they not work at all? or do they sometimes work, maybe if you tap the top of your dash?
    both of those gauges have a three pronged voltage regulator on the circuit board of the cluster, its as simple as remove the cluster, strip it down, desolder the voltage regs and resolder them.
    I think there is an article in the HOWTO section on the temp gauge.
    VR Exec
    Dec 2008
    Penrith, Sydney
    thanx guys im gonna try all of that today except the soildering im gonna get my mate to come and do that im not to good at it lol ill keep you guys updated on my progress
    VR Exec
    Dec 2008
    Penrith, Sydney
    Question
    and i am having trouble finding either of the sensors can anyone point me in the right direction .... im lost.
  1. Car Temp Gauge
    By stig1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-09-2008, 10:57 PM
  2. vl temp gauge
    By frankyj54 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 26-09-2006, 11:22 PM
  3. where should the temp gauge for 5l vt sit?
    By wilko in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-09-2006, 08:39 PM
  4. Temp Gauge
    By Mr_Calais in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 18-07-2006, 07:26 PM
  5. Temp Gauge !!!!?
    By Turbo_dreams in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-06-2006, 01:14 AM
Tags for this Thread
