Results 1 to 15 of 15
Thread: any one know what the stock diff ratio is??
    VR Berlina
    Feb 2005
    bendigo, vic
    Default any one know what the stock diff ratio is??
    hey guys, i got a vr v6 which i converted from auto to manual, and the diff seems to be pretty tall.. i have to keep the revs up pretty high to get it to take off from a stand still. its still running the auto diff at the moment but i have a manual diff here. is there much difference in the gearing??
    Cobez's Avatar
    Cobez is offline LS-EXUAL
    2004 S2 VY SS Ute
    Feb 2007
    VR S Pack - 5 speed
    Sep 2008
    Moorebank
    auto and manual have the same diff ratio.
    i agree it is too tall for the manual box... i'm getting 3.7's soon.
    VR Berlina
    Feb 2005
    bendigo, vic
    thanks guys... so unless i change my centre, im gunna be up for a new clutch on a very regular basis then.. fantastic thats what i want
    Jun 2005
    or learn to drive manual? what revs do you need to take off at
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    VP Executive R-spec
    Jan 2005
    It takes a bit of clutch to get a commodore to start rolling since they are heavy, it'll still last for ages so don't panic about it
    VR Berlina
    Feb 2005
    bendigo, vic
    hey stocky, how bout you come teach me smart arse???? i been driving manuals a long time. dont tell me i cant drive! it needs to be held at least 2500 while easing off the clutch otherwise it stalls.. kinda like the handbrake is on. everyone that tries to drive it, stalls it
    Jun 2005
    well it sounds like somethings not setup right. clutch cable isnt stretched or anything?
    VR Berlina
    Feb 2005
    bendigo, vic
    well i was actually thinkin something like that. the clutch has never felt right since it was put together. and the clutch pedal sits about 60mm higher than the brake.. it shudders all the time.
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    My clutch is the opposite, sits lower than the brake pedal.
    Either way, if your having to use 2500rpm to get going, theres a problem, i can take of at 1500 no probs in my 2 tonne slug!
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    VR Berlina
    Feb 2005
    bendigo, vic
    well my girlfriends dad is a mechanic and he has the car at the moment. he agrees that the problem must lie in the clutch.. he is gunna check it out this week when he gets a chance and see what happens. hopefully its nothing expensive
    VR S Pack - 5 speed
    Sep 2008
    Moorebank
    if you really dont like how tall the gearing is just change your diff gears... get em off ebay for about $150 bucks... not too hard to change probably take you 2-3 hours.. 3.45's should be good if you just want to slip the clutch that little bit less...
    but if your pedal is sitting 60mm higher than the brake pedal then theres definatly something wrong.. did you install the clutch?
    in the bell housing theres a little pivot ball that the cluch fork pivots on and it can be adjusted.. this will change the height of your pedal and will also changed where the clutch engages.. if you're good on the tools you can pull the gearbox off and adjust this yourself... it takes a bit of trial and error so you may have to adjust it and put a few bolts in to hold the gearbox on and test the clutch and then take it off and adjust it more and so on..
    hope this helps man
    Adam.
    VR Berlina
    Feb 2005
    bendigo, vic
    thanks adam, nah i didnt fit the clutch or box.. left that up to a mate. the box is actually coming out of the car this week after finding a lot of metal shavings in the oil. so ill get the man to adjust that ball etc while he is at it
    BE39ER's Avatar
    BE39ER is offline More Torque Less Traction
    94 VR Commodore Berlina just converted to manual
    Jun 2010
    Newcastle
    Are you sure that you gotta take the whole gearbox out just to adjust the clutch? im sure there is an adjustment winder on the clutch cable itself outside the gearbox under the plastic mud cover where the cable meets the clutch cable hook on the box. When you say you converted to manual, did you also change to a manual harness and ECU or you still using the auto pcm and harness? Does your engine light on the dash stay on all the time?
  15. #15
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    I am sure he has it all sorted now mate.
  1. Diff ratio
    By quick308 in forum V8 Development and Modification
    Last Post: 20-12-2007, 07:33 AM
  2. VZ SS ute 3.9 ratio diff
    By gadget in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 19-07-2005, 11:40 PM
  3. Vn Diff Ratio Mod
    By Lee Rigby in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-01-2005, 11:07 PM
  4. Vn Diff Ratio Mod
    Last Post: 14-01-2005, 08:07 AM
  5. VK Diff ratio changes
    By kiwiVL in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 07-05-2004, 09:57 PM
