Results 1 to 3 of 3
Thread: transmission code 6.8
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    Default transmission code 6.8
    Code 68 - Transmission Component Slipping - Auto Transmission Only
    can that be fixed with a solinoid change or does that mean my clutches inside are rooted and nothing is going to be able to fix it. im getting good 1st and 2nd but no 3rd or 4th as it just high revs
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Solenoids will show a code 81 or 82 from memory. If there is still a bit of forward motion in 3rd/4th then maybe a can of 'trans stop slip' might help - it makes worn clutches grip better but cannot work miracles. I've noticed SuperCheap have a new range of Lucas products in cans to fix everything (if you believe what they say on the can). Whatever, $12 is cheaper than a reco (which is inevitable)
    Set of thongs
    Dec 2005
    Stonedville
    hehe its all cool gearbox died
LinkBacks (?)
  1. code 28 what do i do!!! vs auto transmission oil pressure
    By SKNOT9 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-12-2008, 01:28 PM
  2. Code 68 - Transmission Component Slipping - Auto Transmission Only
    By tysons_2001 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-12-2006, 05:14 PM
  3. Transmission Code
    By 05 VZ SS in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-05-2006, 08:33 AM
  4. Code 68 - Transmission Slipping
    By GMH 72 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-04-2006, 11:02 PM
  5. Transmission fault code 85?
    By accentstencil in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-01-2006, 01:09 PM
