Results 1 to 3 of 3
Thread: Engine Knocking so i need another
    vs executive
    Jan 2008
    Default Engine Knocking so i need another
    Hi i have 95 vs commodore executive v6 manual. My car has done 320,000 kms. I'd notice my car had lost a lot of grunt, when i was driving a while ago. I had it checked out and was told my that my engine had a knock and that it was on its way out and i would need a new one or a rebuild, obviously.
    I want to know:
    - How do i tell what model transmission ive got
    - How much am i looking at for a 2nd engine and what model it is, because its to expensive to pay someone to rebuild it and i dont have a garage.
    - How much for a V8 and how much more to fit roughly
    - What kind of problems would i come across
    Ive been told the vs engines were made to a specific model transmission for exapmle i would need an "adaptor" to fit a vs auto engine to a manual transmission.
    Cheers Hayden
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    Being a 95 model VS its a series 1 so it will have a Borg Warner T5 (assuming it has not been changed at some point). If its cable operated it will be a T5. You can also check the compliance plate on the firewall (passenger side) and it will tell you there under 'Trans'. A new motor will probably set you back around $400 at a guess but shop around because some wreckers will charge heaps more than others. Ebay can also be a good place to look as they usually go pretty cheap on there. From what I know the crankshafts are different between a manual and auto ecotec motor however you can still fit a manual box behind an auto motor, with the downside being that the flywheel will only be held to the crank by the mounting bolts whereas a manual crank also has small dowel pins to locate it.
    vs executive
    Jan 2008
    Cheers mate for your help, i was checking the compliance plate and it said my transmission is a m78 and my engine is ls2 my model is VS8VK19-115
  1. Engine knocking
    By d_neo_b in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-01-2009, 10:09 PM
  2. loud knocking sound in engine bay **youtube link**
    By roon_VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-04-2008, 09:16 PM
  3. Knocking noise in engine at startup when cold
    By sebstenator in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-02-2008, 05:56 AM
  4. VT 5.0L Engine Knocking Noise?
    By Spitfire in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-08-2006, 08:06 PM
  5. engine knocking noise
    By grigor in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-01-2006, 06:06 PM
Tags for this Thread
