Results 1 to 12 of 12
Thread: ECU or bad tune-up?
    alex673's Avatar
    alex673 is offline Alex673
    VS Executive S1
    Oct 2006
    Gosnells WA
    Exclamation ECU or bad tune-up?
    Hey guys,
    I have a '95 VS series I with about 249,000KM's on the clock. It's a bit tired, looks a bit shabby, but has been extremely reliable. (Most of the km's are highway)
    Anyway, I had a major service and tune up done a few months back, and have noticed 2 distinct problems...
    1. The fuel economy has gone up the sh**! I used to get about 450km in the city prior to this service, and now am lucky to get 250. My driving habits haven't changed, and the only difference post service is a new battery
    2. The trans slams into gear late, and no matter how you drive, it is no longer smooth in changing gear. The only plus is that it goes a lot quicker on takeoff...
    My feeling is that the mechanic has somehow stuffed up the standard tune of the car, and it is running extremely rich, thus the crap fuel economy and the extra power on take off. Does this sound feasible, or am I just thinking too much into it?
    A friend of mine suggested that I reset the ECU with the battery disconnect, then crank it and rev to 3000RPM for 10 Seconds... Tried it, but didn't seem to make any difference.
    Any advice would be appreciated.
    Alex
    danja's Avatar
    danja is offline Swerves for gay koalas
    CBF 250 and a Levin ZR
    Mind Me Bloody Beer Champion!
    Jan 2006
    The tune is electronic, you can't screw with it accidentally
    Possibly he's screwed up a sensor? Have you checked out your MAF, O2, TPS sensors?
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    the delayed gear changes dont sound health, and will hamper fuel econ, its prolly due for a trans service or reco. generally o2 sensors as danja meantioned, often are overlooked and havent been changed since rolling off the factory.
    whats been serviced lately, replaced, or changed?
    alex673's Avatar
    VS Executive S1
    Oct 2006
    Gosnells WA
    Quote Originally Posted by ephect View Post
    The only thing that has been changed lately is the battery. I watched the mechanic spray some sort of hi octane cleaning fluid through the plenum and intake, and bucket loads of carbon build up came out, but apart from that it was just a normal service and tune up.
    Don't know if the above is relevant though...
    Alex
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    i would start with checking error codes, located in the how-to section, this should point you in the right direction and tell you if its logged anything thats failed.
    o2 sensors would be next on the list, get new ones on there, combine that with a service including air, fuel and oil filter. change plugs and leads.
    Free Stuff: remove the throttle body and its sensors and giving it a good hit with some carby cleaner. Check all hoses for cracks or vacuum leaks.
    all listed above should get your engine running smoothly.
    if the oil hasnt been changed in a while, i would change it and the filter, and after 1000kms do it again filter included, kinda like a flush out, its might seam a waste but will ensure its clean. i believe there is a product you can buy to add/replace that flushes the oil system
    aceventura's Avatar
    aceventura is offline Doesn't drive like this
    Mazda 6
    Oct 2008
    SEQ
    Quote Originally Posted by alex673 View Post
    Can't some of these cleaning compounds foul the O2 sensors, maybe even the carbon build up the cleaner dislodge is fouling the sensors?????
    Just a thought
    VZ LS1 Calais
    Dec 2005
    South Brisbane
    there is no such thing as a "tune-up" on a modern car, thats a term used for carby engines.
    so get that idea out of your head, there's nothing your mechanic could have done to the tune. its all set and electronic and can't be changed without tuning on a dyno with a program like kalmaker.
    its more than likely just a coinicidence that something has gone and started playing up after your service.
    the fact that you changed the battery also would play a part in your cars change. it would have reset the pcm and would now be running off base tables from the factory tune till it starts to self learn a bit and get where it needs to be.
    Quagmire: My fellow Americans, I have not been entirely truthful with you. I did gagoogidy that girl. I gashmoygadied her gaflavity with my googus. And I am sorry.
    99 VS 'S' Utility
    Dec 2006
    Lansvale NSW
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Alex
    Very relevant. I'd say the crap that the cleaner has dislodged has blocked the idle air control ports in the throttle body. Take the throttle body off the car for a proper clean.
    Visit my Facebook page
    Munz's Avatar
    Munz is offline Right Foot Action
    VZ Calais LS1 / VL RB30e daily
    Jan 2011
    Brisbane NTH
    hopefully he would have sorted it by now abba.......lol
    they got you good!!!
    EASY $30 DIY Cold Air Induction!
    Quote Originally Posted by stuffedifiknow View Post
    would this mod work like forced induction.
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Shit.....I always do that.....I never check the posting date.
    Munz's Avatar
    Jan 2011
    Brisbane NTH
    Thats alright still good info about the iac, I'm sure it will help someone out
  1. To Tune or not to tune???
    By ianf in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-03-2011, 01:59 PM
  2. Maf tune vs Mafless tune
    By Senator Slash in forum VY Holden Commodore (2002 - 2004)
    Last Post: 01-02-2009, 09:25 AM
  3. Do I need a re-tune/flash tune
    By Lowclubby in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-12-2008, 02:03 PM
  4. Tune Up?
    By kanevss in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-03-2007, 10:16 PM
  5. Tune
    By statey27 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-11-2005, 05:39 PM
