Results 1 to 7 of 7
Thread: immobiliser problems
    VS lexcen
    Feb 2009
    Default immobiliser problems
    i am having trouble with my vs lexcen yesterday i went to unlock the car my keypad wouldnt work so i unlocked the door manually i went to start the car and it wouldnt start as the immobiliser wont turn off, went and brought new key (the old one had been playing up this was my first thought) however it still wont turn off the immobiliser.... Any ideas on what could be the problem????
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    It could be the BCM. I doubt if it would be the key reader since you couldn't unlock the car either. Those were the symptoms for me when I had to replace the BCM. I would try disconnecting the battery in a hope that it might reset the BCM if it has frozen like computers often do. It might not help but it's worth a shot.
    MY RIDE
    96 VS II Acclaim
    Dec 2007
    Did you cycle the ignition before trying to start with the new key?
    eg: OFF - ON - OFF
    Had a new key cut and coded this morning and this what they told me to do.
    VS lexcen
    Feb 2009
    I`ve cycled the ignition the mongrel at the key joint drummed that in my head when i went back. The battery idea was a fisser but thanks for the help guys now
    ill try the BCM *DAMN IT* the prices im getting are ridiculous !!!!thanks again!!!!
    VB SL/E
    Dec 2008
    Leave the ignition on with the drivers door open till you hear the beeps then try to start it.
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    everytime i've had a new key coded to my car, i've just put the key in and driven away.. i dont believe there is any other way apart from having the key matched to the bcm via a tech1..
    VS lexcen
    Feb 2009
    Hey guys thanks for all the tips i ended up buying a second hand bcm with key for $75 now it works a treat
  1. HSV Key/Immobiliser Problems
    By akwoods in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-11-2010, 02:38 AM
  2. immobiliser problems please help
    By mr_vl in forum Electrical Wiring / Questions
    Last Post: 08-09-2008, 05:25 PM
  3. Help!!!! Immobiliser problems
    By snmcdon in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-05-2006, 09:19 PM
  4. Immobiliser Problems
    By eh2o in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-04-2006, 09:27 AM
  5. BCM / Immobiliser Problems in VP
    By pacey in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-03-2006, 11:17 AM
