Results 1 to 10 of 10
Thread: Help needed blinkers wont stttoooppppp
    VR Exec
    Dec 2008
    Penrith, Sydney
    Question Help needed blinkers wont stttoooppppp
    heya all my blinkers wont stop blinking and the car wont lock ive checked fuses changed the hazzard switch and nothing its still doin it hellppppp pleaaaseee
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    As a stop-gap measure disconnect the battery - reconnect and see if its the same. If it is and you're worried about leaving the car overnight then disconnect the battery again, mmanually lock all doors except drivers and deadlock the drivers door.
    When there is more light to fault find start checking your wiring around the steering column. If there has been any recent electrical work done check that first.
    VR Exec
    Dec 2008
    Penrith, Sydney
    ok thanx ive already tried doin the battery thing but ill have a look at the wiring today
    Hodz91's Avatar
    Hodz91 is offline CRuiZn..Lookn 4 A.B Cover
    95 VS Berlina
    Aug 2008
    Perth W.A
    Check wiring something could be creating a short resulting in constant power to the lights.
    VS Berlina 1995 3800V6 W.A
    OzJD's Avatar
    OzJD is offline Not your average Joe.
    VR6 S1 & VR6 S2
    Feb 2009
    Parramatta, NSW
    I know you said you've changed it, but sounds like hazard switch fault.
    Current mods/repairs:
    Power Windows Installation (70% Complete)
    Current Issue(s)
    N/A
    My Holden doesn't leak, It's just marking it's territory!
    Quote Originally Posted by 88GreenVN View Post
    Missing teeth from the diff is terminal as in diff no worky. Crunch crunch bank snap and then STOP.
    VR Exec
    Dec 2008
    Penrith, Sydney
    OzJD's Avatar
    VR6 S1 & VR6 S2
    Feb 2009
    Parramatta, NSW
    What was the problem? If you post it then the next John Doe searching for an answer might have some luck.
    Current Issue(s)
    N/A
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Quote Originally Posted by Chief VR View Post
    yea its ok ive found the problem thanx for all your help
    Yeah nice, why dont you add to the communities knowledge base and post what the problem was. Just a little selfish there.
    Reaper
    VR Exec
    Dec 2008
    Penrith, Sydney
    ok the problem was (dont laugh by the way) im from a VR and i moved up to a vs and i thought the remote for the vs was the same as the vr so i thought only one button would work so it was me pressing one button when i should have pressed the other button and it was the silent alarm going off all the time. so yea i feel stupid
    VrWagz1's Avatar
    May 2008
    wollongong
    Thats not stupid, just a simple over sight. But good to know as somone may do the same thing one day and come across this thread. nice work.
    Reaper
  1. Blinkers wont stop and security is nill
    By Chief VR in forum Electrical Wiring / Questions
    Last Post: 06-02-2009, 12:04 AM
  2. degreased motor now wont run...help needed urgently
    By canabl in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-11-2008, 12:45 PM
  3. urgent help needed, car wont start at all.
    By steak000 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-11-2008, 01:27 PM
  4. blinkers wont self cancel
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 08-10-2005, 11:45 AM
  5. No Airbag Or Blinkers
    By shigan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-04-2004, 02:26 PM
Tags for this Thread
