Results 1 to 7 of 7
Thread: Is it the Fuel pump?
    vs commodore wagon
    Dec 2008
    Default Is it the Fuel pump?
    Gday again JCers.Still got the original problem 0f stalling.Stalled for the third time but this time with the tinny on the back.Getting pretty sick of being a traffic cop directing traffic around the VS wagon.Gees theres some dead set nutters driving out there.Left it for an hour and started up and i drove home 10 mins away,as with the other 2 times.Changed plugs,leads cas,injectors,dfi and a faulty tested coil,cleaned throttle body.Im thinking of changing the fuel pump relay,fuel filter and fuel pump to an ac delco.Car runs perfect then just shudders and then stalls.And wont start. Any suggestions?
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    vs commodore wagon
    Dec 2008
    Gday.Not the cas again.Was replaced only a month or so ago and stalled 2 days later again.What are they makin these things with chocolate.
    May 2005
    .....SE Burbs
    faulty cas? sounds casy.... the vs' go through cas' like i go through tissues when im single.
    may be the pump... but id say cas.
    aZk.
    vs commodore wagon
    Dec 2008
    No worries,ill get another one from Holden and wack it in.Might do the fuel pump and filter too.Have owned the car for 7 years and never replaced the cas.Until a month ago.But replaced fuel pump and filter about 4 years ago.Thanks.
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Could be the pump. But have you looked into the imobiliser possibly the contacts around the key barrel. When it stalls is the red light flashing in the center console.
    When it stalls can you hear the pump run for a few seconds when you turn the key to accessories just before you start.
    Reaper
    vs commodore wagon
    Dec 2008
    Gday Wagzy.No havent paid attention to the red light,but will if it happens again.Cant hear the pump like usual on startup after it stalls.But can hear on startup and when running from the back as usual.When it starts normally.
  1. cracking open fuel tank to change fuel pump?!
    By VS5spdV6uteowner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-01-2009, 08:00 AM
  2. Will a fuel pump pump oil?
    By VYMAD in forum General
    Last Post: 12-11-2008, 09:07 AM
  3. Fuel pump issue, or fuel line blockage? not sure help!
    By SKNOT9 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-09-2008, 02:08 PM
  4. leaking fuel damper and fuel pump adventures
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-08-2006, 04:00 PM
  5. VS Internal fuel pump issue (duel fuel)!!!
    By futronix in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-09-2005, 08:10 PM
