My Vr Calais climate control is not working please help!! All buttons work display works but when it is on auto and speed 1 and 2 it doesn’t work but on 3 it dose please HELP!!! What do I need to do to fix problem?
This link should do the trick for you:
Climate Control Fan Not Working On 1&2
Thanks heaps! So from what I get from that, my best bet is to just buy a hole new climate control unit n replace?
If it is only your fans not working on speeds 1 or 2 but ok on 3 then it is the fan speed resistor located under the plastic vent cowling that sits under your wiper arms.
The wiper arms and the rubber strip along the back edge of the engine bay need to be removed before carefully removing the very thin plastic vent cowling cover.
Over on the passenger side you will see a littlesquare mesh type looking box that is the resistor.
HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
Almost....
For climate control models its called the fan amplifier, it sits closer to the middle of the bottom of the windscreen under the plastic cowling where the wipers are. Its in a little plastic rectangular shaped box from memory. You need to undo this box and then the fan amplifier is located underneath. Its basically just a big transistor with a whopping great heat sink on it, looks a bit like echidna spikes!
Ok so... It’s under the windscreen wipers under the plastic cowling..? Do you no if it a part easily replaced and easy to buy? Or is it maybe a job for some 1 that no's what the doing?
