Results 1 to 3 of 3
Thread: What purpose do these serve?
    vs commodore wagon
    Dec 2008
    Default What purpose do these serve?
    Jcers.What are the 2 spaghetti hoses that connect into the top on the outside of the VS wagon fuel tank that lead to the filler neck connectors on the other side? When i blow into one it blows through no problem with a short pipe in the tank(couple of inches).But when i blow into the other one though the long pipe in tank,it doesnt budge.Is it supposed to blow through? Thanks again.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    They'd be the breather pipes to the filler - it's possible one will have a one-way valve on it but I'm not really sure.
    social's Avatar
    social is online now Ute Finatic
    MY06 6.0L VZ Thunder(na naa na naa..)
    Nov 2008
    South Aus
    if blowing thru dsnt work try suckin it and see if you get anything haha
  1. Whats the purpose of this
    By Simon W in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 16-11-2008, 02:22 PM
