Results 1 to 11 of 11
Thread: Key not working.
    1994 VR Exec, 5.0L BT1
    Jan 2005
    Default Key not working.
    Hey,
    Have a problem I NEED to fix asap. My key isn't turning in the ignition. Have not had any problems untill this morning. I took it to get washed then when I went to leave the key didn't turn. It did work twice after it was washed, so I don't think it was anything to do with that. After 20min of fiddling it turned and I was able to get home but as soon as I got home it wouldn't work again.
    My dad has lost the spare key that I gave to him, so we can't check if it's just the key or the ignition barrel. We're gnna keep looking, hopefully find it.
    Is this more likely to be the key or the ignition barrel? Who would I go to to fix something like this? Any help GREATLY appreciated.
    Thanks, John.
    Jan 2005
    Found the spare! But it's not working either. Does this mean it's the ignition barrel? Can someone tell me what I should do? Is this a mechanics thing or autoelec. Am I looking at an expensive job? Will I have to replace the keys aswell? Really need the car by monday as I use it for work, and there's no public transport where I'm working atm.
    VXII SS M6 & Leather
    Nov 2003
    Warrnambool
    wobble the steering wheel as you try turning the key.
    steering lock might be activated.
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    I reckon it is the barrel, it is a very common problem.
    MY RIDE
    Maranello red Vn V8 Calais
    Jan 2009
    yeah give the steerning wheel a rattle, if the steering lock is 100% & engaged cars will do that, other wise it sounds like your up for a new barrel, better to get it done now than later when it gets even worse.
    Jan 2005
    Thought it might have been the steering lock, and did wobble and shake it alot, but just couldn't get it to work. I've called a locksmith and they're coming out to replace the barrel. $250 later But at least I won't have to worry about it nemore.
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by spd_dmn View Post
    That's about $200 for 15 minutes work plus travelling time , but at least it will be fixed.
    MY RIDE
    Jan 2005
    Well I called around and the prices I was getting for the barrel were between $80-$120. But as you said, at least it'll be fixed And I dun wanna be working in the car in this heat, especially coz it's parked in the sun with the windows up coz no electrics
    OZ-18-OI is offline OZ-18-OI
    1995 VS Exec 5 Speed & 1996 VS Commo Acclaim
    Dec 2007
    Jan 2005
    Barrel replaced, all fixed now. Just gotta get the keys re-cut on advice. But that'll only be bout $25 a key. My baby is going again
    Fekason is offline Fekason
    MY11 VE Series II SV6 Manual
    Mar 2005
    Penrith NSW
    Default Too Late!!
    Hi,
    I know that I am too late, but I have heard of VS ignition barrels sticking. Some people have sprayed MD40 or similar into the key hole, and then wriggled the key. Sometimes takes a few goes, but I know of one instance where the barrel is still going strong about five years after using this trick to get it going.
    Cheers.
  1. Sub not working
    By whitevrboi in forum Car Audio
    Last Post: 06-09-2008, 12:15 AM
  2. AC fan not working??
    By commo69 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-03-2008, 11:40 AM
  3. lpg not working
    By vh ~ very horny in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 30-04-2007, 06:26 PM
  4. Fan not working
    By croz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-05-2006, 09:23 PM
  5. VK Fan not working
    By Kevin in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 23-02-2005, 04:41 PM
