Results 1 to 4 of 4
Thread: Speedo reading low
    VS Exec Series II
    Mar 2005
    Default Speedo reading low
    Hey guys,
    I've compared my cluster speedo to the speed warning unit and its lower by about 5kms. When I bang the dash it comes up and reads correctly.
    I've tried soldering the voltage regulator as has been suggested but no good.
    Is there anything I need to do to the speedo unit itself? I've tried resoldering the joints on the back but that didn't help either so I don't think it's a dry joint.
    Thanks
    VZ SV6
    Oct 2008
    Newcastle NSW
    yeah my vs needs a good bang over the dash to 'update' the dials as they all lag behind a bit except the tacho. try driving at a constant speed then slowing down i bet you if you hit it, it will drop down a bit more as its lagging behind the actual braking... heaps of commodores have this problem.
    VS Exec Series II
    Mar 2005
    Quote Originally Posted by alex2_s View Post
    Yeah that's exactly what it does...does that mean that the mechanism needs lubrication?
    Has anyone managed to fix this or do I need a new speedo?
    BTW, Holden quoted me $470 just for the speedo unit!!!
    VS Exec Series II
    Mar 2005
    OK, I took the speedo unit apart including the centre threaded plastic guide and lubed it all up with silicon spray.
    I also widened the hole slightly in the guide as it looked like I slightly bent the pin when removing the needle when I fixed my odo cog.
    Put it all back and noticed that the needle operation was much smoother as it returned to zero.
    I've just come back from a drive and it's about a 2km lag now which drops to 0-1km when cruising. I guess this is the best I can expect from a 300k cluster.
    Hope this helps someone.
  1. VX SS Digital Vs Analog speedo reading
    By ozengines in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-11-2008, 10:25 PM
  2. 20s and speedo reading?
    By VL-187 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-01-2007, 05:26 PM
  3. speedo reading wrong
    By burns#44 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-11-2006, 09:10 PM
  4. Speedo not reading accurately
    By VL3.0 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 30-04-2006, 02:44 PM
  5. Speedo Not Reading Correctly
    By driscolld in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-03-2006, 03:57 PM
