Results 1 to 14 of 14
Thread: Help, Leaking coolant though bolts (+pics)
    VR Executive S 3.8
    Oct 2007
    Default Help, Leaking coolant though bolts (+pics)
    While searching for a coolant leak, I came accross this bolt which was leaking coolant. Its located behind the starter motor (See pics). Bolt size is 3/8", and there are 6-8 of them on both sides of the engine.
    I'm just wondering what these bolts are for and wheither its normal for them to be leaking coolant?
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    Looks like an inlet manifold bolt?
    One things for sure.. that aint your starter motor its ur alternator.
    VR Executive S 3.8
    Oct 2007
    Well shows what I know. Anyone know what this is for, and wheither it is normal for coolant to be in there? Or do I have a blown head gasket or something?
    Ozzie's Avatar
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    Its hard to tell from those pics.
    Might just be your inlet manifold gasket by the looks of it.
    Does the exhaust blow white smoke?
    Do you get oil in the radiator?
    VR Executive S 3.8
    Oct 2007
    keza87's Avatar
    keza87 is offline JCCC NSW Member
    VX Wagon S3.8 M5
    May 2006
    It is definitely your intake manifold gasket. I had the same issue in my VR but it also had water in the oil and that's the next indication.
    Either way the intake manifold needs to come off to replace it.
    JCCC NSW Member
    Check out my ride here : VX Manual Wagon with VZ Senator front end now Supercharged
    Just Commodores NSW Chapter. Join in for a cruise some time!
    Click here for more info
    VR Executive S 3.8
    Oct 2007
    If there was coolant getting into the inlet manifold, why would it be forced out of these bolts? Wouldn't it just sit at the bottom of it?
    Also, say my gasket needs to be replaced, how bad is it for the engine if I kept driving around like it is?
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    Coolant under pressure will go anywhere it finds a path...
    If the leak is bad enough your cooling system won't hold pressure and you could overheat the engine, so yes, potentially very bad. make sure you keep the coolant topped up until you do the gasket.
    Mar 2004
    Get somebody to pressure test your system for you. It is quite likely that the radiator, a hose or the pump is leaking and blowing coolant back over the motor giving the appearance that the manifold gasket is leaking. This could explain why there is no water in the oil or white smoke. Could save you a lot of unecessary time and expense.
    Cheers,
    Tom.
    VR Executive S 3.8
    Oct 2007
    Cheers, but I have new radiator/hoses/etc. I could acctualy see the coolant comming up from the bolts. How many bolts hold the inlet manifold on anyway?
    What about those radiator stop leak additives? If it stops the leak is it fixed???
    VS l67 statesman
    Dec 2008
    try taking the bolts out and putting permatex on the threads,some mannuals recomend this on bolts near water jackets and dont be stingy with it
    VS l67 statesman
    Dec 2008
    VRII 94 Exec
    Mar 2011
    Hervey Bay
    Similar thing just happened to me, i replaced the inlet manifold gasket, and forgot to put silastic on the threads of the bolts, handy hint i learned on this forum
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    Quote Originally Posted by VEEARR View Post
    Except for the part where you do not bump old threads :P
  1. Coolant leaking from something...
    By LightningVP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-11-2008, 12:59 AM
  2. leaking coolant
    By quiksilver1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-04-2008, 10:11 PM
  3. Leaking Coolant
    By Slow VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-05-2006, 08:49 PM
  4. Coolant Leaking Help Vn
    By WeBsTeR in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-01-2006, 08:18 PM
  5. Leaking bolts
    By niggle in forum VL Holden Commodore (1986 - 1988)
    Last Post: 02-05-2004, 08:46 PM
