Results 1 to 2 of 2
Thread: tension pulley VR
    VR Calais
    Jan 2009
    Smile tension pulley VR
    Have a small problem hoping someone can help me out with. I have a Vr and just purchased a tension pully from the wreckers. Holden had told me it needed replacing but the wreckers gave me the whole bracket which seems when looking at it that you have to take off the Alternator. I thought you could just undo the bolt on the tension pulley itself and replace it that way.
    Thanks Sutto
    aceventura's Avatar
    aceventura is offline Doesn't drive like this
    Mazda 6
    Oct 2008
    SEQ
    Quote Originally Posted by sutto View Post
    Thanks Sutto
    I am not quite sure why you went to the wreckers - The pulleys are only about $25 new. Anyway to replace the pulley you need to be a little careful, you have to turn the centre bolt clockwise to undo (LH thread).If you screw something up you will need the bracket the wreckers gave you.
    Anyway there are plenty of threads on this - Have a look
  1. WHATS BEST WAYTO change drive belt tension pulley on hsv LS1 V8
    By gazzabrizz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-02-2006, 08:41 PM
  2. tension pulley replace
    By k191350 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-09-2005, 11:46 AM
  3. tension
    By sick vs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-08-2005, 06:06 PM
  4. auto tension pulley and stabiliser bar rubbers
    By muney in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-06-2004, 05:19 PM
