Results 1 to 4 of 4
Thread: Better earthing point for a V8 02 CTS
    undar8ed1's Avatar
    undar8ed1 is offline Rags 2 riches!
    2 VXII V8 dailys
    Feb 2008
    regional W.A
    Default Better earthing point for a V8 02 CTS
    The earthing point on the back of the passenger side head for the 02 sensor and CTS/TPS is there a better spot I can use? I`m getting fustrated as I`ve cleaned it and freshend the connections and still has the same codes indicting a bad earth problem had the exact same codes on my girlfreinds V6 and just cleaning them fixed the problem. So I`ve seen a how-to for moving the ones on the V6 to the engine cover studs but what about the V8, any one got any strong earthing point suggestions? I wan`t to tackle it this W/E
    and my RDO tommorow
    undar8ed1's Avatar
    2 VXII V8 dailys
    Feb 2008
    regional W.A
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    is there an chain mount point at the back of the engine there at all you can use? im not too familiar with the 8 for mounting points.
    What might be a benefit to you whilst tackling eathing points, is to get some extra wiring and do a hot earth kit which should improve the earthing problem.
    skweek's Avatar
    skweek is offline vr 355
    vr commodore
    Oct 2006
    albany
    have u upgraded the earth wire that goes from ur battery to the motor, they have alot of problems with the factory one being to small
    when i get sad, i just stop being sad and be awesome...true story!
  1. New Speed Cameras - Point To Point
    By jaskel in forum The Pub
    Last Post: 16-10-2008, 08:58 AM
  2. vs earthing prob.
    By alan smithy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-09-2008, 01:52 PM
  3. VT Cambering? 4 point and 2 point
    By raZel in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-04-2007, 08:55 PM
  4. Earthing Issue Maybe?
    By Sabbath' in forum Electrical Wiring / Questions
    Last Post: 07-07-2006, 06:32 PM
