Results 1 to 8 of 8
Thread: vs ute rear bumpstop rubbers
    vs ute
    Mar 2007
    Question vs ute rear bumpstop rubbers
    PLEASE HELP,
    my vs ute has been lowered about inch and a half all round,problem i am having is it bottoms out with only 100kgs of weight in the rear.when i had look
    underneath there was about 10mil of clearence under the bump rubbers.
    i then check a friends,which is also lowered and it had about 50mil of clearence.i could see some markings on the rubbers i.e 80,75,70,65,etc
    with a line in between each number,should these be cut down or replaced
    with shorter rubbers.
    Vs SIII Ute
    Feb 2009
    I had the same problem when I lowered my ute. I then fitted lowered bumpstops and all's good. They're not expensive from memory.
    vs ute
    Mar 2007
    VU II SS
    Mar 2006
    Enter the Model/Class of your Commodore. i.e. VL C
    Sep 2008
    Maranello red Vn V8 Calais
    Jan 2009
    you can cut them down but it shouldnt be bottoming out by only going 1 1/2 inches lower than stock.... are they proper lowered springs and how old are the shock absorbers?
    bump stops are there to protect your shocks i wouldnt go taking them out altogether.
    VR V8 S pack Ute
    May 2005
    yerp my utes lowered a similar amount and i chucked a big block chevy motor in the back and it didn't bottom out.
    Chirpstr's Avatar
    Chirpstr is offline A new project attack
    VR Berlina M5, VP M5
    Sep 2007
    Just cut them back a little and it will be fine.
  1. VN Door Seal Rubbers
    By stockies in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-12-2007, 02:44 PM
  2. Strut rubbers
    By vt_lover in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-12-2007, 06:46 PM
  3. How to know if you need new suspension rubbers
    By Wingnut0021 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-03-2006, 07:10 PM
  4. Door Rubbers
    By wooly72 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-11-2005, 10:28 AM
  5. Door Rubbers
    Last Post: 22-11-2004, 08:25 PM
