Results 1 to 22 of 22
Thread: wgon springs in sedan?
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    Default wgon springs in sedan?
    as title says can i put wagon rear springs in a sedan? there super low king springs btw
    cheers
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    ozzie yes u can but they are not as lower as the sedan ones and more heavy duty. im riding with wagon springs in my rear
    hakhawk's Avatar
    hakhawk is online now smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    Quote Originally Posted by Zuicider View Post
    correct, assuming the sedan is live axle and not irs.
    vr wagon, vx executive
    Jan 2005
    hakhawk's Avatar
    Jan 2005
    not heaps, but a bit more than wagon springs. the difference in rates is because you can stuff more crap in the back of a wagon. so once you start loading it up on sedan springs, it sags heaps
    Jan 2005
    so i will have to get irs wagon spring my the wifes sedan to tow the trailer.it sags when towing
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    ^^^^^i got some HD rear vr wagon springs here if ya want em cheap. Good for towing
    Reaper
    hakhawk's Avatar
    Jan 2005
    Quote Originally Posted by minimefx View Post
    just order heavy duty sedan springs for the vx.
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    VrWagz1's Avatar
    May 2008
    wollongong
    you would probably wear out the exhaust tip
    Reaper
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    haha hmm so it will make it lower/ish? if s cool as atm the rear ass sits wayyyyyyy high:P
    plus i think one side has sagged and i only have a set of rear sedan springs that came out of me VS with 80 000 on the clock (at the time) and made the car sit like a truck haha
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    so if i put lowered sedan springs in my wagon it will drop heaps.
    No it won't drop the rear heaps just a little more than on a sedan, like having 1 passenger in the back.
    Some of these guys are talking through their backsides.
    A VS wagon is only about 40kgs heavier than a VS sedan (exucutives).
    I've had Kings KHPR24sl (superlow) in my wagon and found it too low (bad driveway) but kings KHPR24 (wagon lowered) were too high.
    So now I use KHRL20 (Sedan lowereds) and it sits just right.
    I could use KHRL20HD (heavy duty) for the same static height but the ride would be harsher as they have a thicker wire.
    Heavy duty's would be the way to go if you were using the car for towing or carrying heavy loads.
    SW
    HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
    VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    Quote Originally Posted by jas98 View Post
    cheers
    My original superlows are in a mates VS BTI ex cop car and it sits like FE2 but rides better than the stock FE2 springs which came with the car and weren't variable wound.
  15. #15
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    well it turns out that the springs i had in mind that i could have got cheap.......me stupid mate cut them!!!!! y he did not put his brand new ultra low springs in the he got the same da (that he cut them) i don't know. oh well
    as the back sits rather high i may just see how the sedan spring sit...
    cheers
  16. #16
    Nzpure's Avatar
    Nzpure is offline VS L67
    1997 Vs Supa6
    Aug 2008
    Christchurch
    well i put dobi superlow wagon springs in my wagon they were no lower then low wagon springs which actually sat higher then the oem springs that were in there so i put superlow sedan springs and it droppd it heaps i mean more then 2 inches heaps
    Wheel Tuck FTW!!!!!!
  17. #17
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    Quote Originally Posted by Nzpure View Post
    Superlow sedan springs in a wagon would drop it heaps, be like using wagon ultra lows (kings khpr24sssl).
    But the original question was can he put wagon springs in a sedan.
  18. #18
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
  19. #19
    Nzpure's Avatar
    1997 Vs Supa6
    Aug 2008
    Christchurch
    yes he can
    the part numbers for the seats are the same
    o how i love working at a dealership =D
  20. #20
    Nzpure's Avatar
    1997 Vs Supa6
    Aug 2008
    Christchurch
    sedan springs fit in wagons wagon springs fit in sedans vs-vr they do anyways thast Live rear i mean
  21. #21
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    now i wanna know if i could put sedan rear springs into a wagon:P
    Yes you can already elaborated on this in post #13
    SW
  22. #22
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    SW
  1. vp sedan springs to vr wagon
    By elmo_90 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-09-2008, 08:46 PM
  2. Sedan springs in a wagon?
    By TWOJZ in forum VL Holden Commodore (1986 - 1988)
    Last Post: 01-07-2008, 07:26 AM
  3. Will VN Sedan Rear Shockers / FE2 Springs fit into a VH Sedan?
    By VHSLX3300 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 21-01-2007, 12:28 AM
  4. sedan springs in a wagon
    By slappa. in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-09-2006, 08:57 AM
  5. Wagon and Sedan Springs...
    By raZel in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-08-2005, 10:10 PM
