Results 1 to 9 of 9
Thread: vs box heating up??
    vs berlina
    Dec 2008
    Default vs box heating up??
    the plastic thrust bearing holder in me t5 box keeps getting too hot n melting..second1 ive replaced...the shaft it slides on doest spin....any ideas??
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Maybe the thrust bearing is contacting the clutch fingers all the time and overheating - have you checked the release lever pivot ball height as this can cause it to drag if not adjusted properly.
    vs berlina
    Dec 2008
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    then you will have to adjust ya pivot point which means taking off ya box i think its 102 mm from the top of the pivot to flush with the bellhousing face for v6 or 106mm for v8 or around about and loosen ya clutch cable a tad
    vs berlina
    Dec 2008
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I don't think there is (none shown in Gregorys) - if the pivot is properly adjusted and the cable is not jamming (and also properly adjusted) the thrust bearing should not be in contact with the pressure plate fingers.
    Is the actual thrust bearing in good condition? - if it's dry it will overheat and also squeal.
    vs berlina
    Dec 2008
    yea,the bearing was new,,ill adjust the pivot wen i throw the box back on n see how it goes.thanks
    vs berlina
    Dec 2008
    anyone rekon the heat from the extracters could of went in the bell housing causing the carrier to melt??cause its melted n actually fused on the shaft stopping the clutch working..maybe due to 10 mini burnout??the bearing seems to be still new but
    vs berlina
    Dec 2008
    figured it out,,,when u do a manual conversion make sure u put a spiket bush in the crank.....
  1. No heating
    By Shortstuff in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-07-2006, 12:29 AM
  2. car is over heating.... but not?
    By Fully in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-07-2006, 11:09 PM
  3. over heating
    By geardys in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-07-2006, 06:26 PM
  4. heating
    By sulley in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 07-07-2006, 08:31 PM
  5. VS heating up...
    By Gobbles in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-07-2004, 10:07 AM
