Hey Guys,
Need some help with my Series 3 Vs ute. With a getrag gear box.
Here are my questions, and ideas.
I have got a "Billet" Short shift kit, And have always found it hard to shift into 1st gear unless going very slowly. I mean very. Almost stopped. And have to double clutch and give it a rev occupationally. Its been there with the original shifter also.
I am wanting to know what is causing this? Clutch or what? I'm not sure.
So please discuss and help a mate out.
BTW, Very happy with the "BILLET" Short shift. Best upgrade i have done on my car. Wicked recommend to anyone.
Could be wrong but it sounds like your box is overdue for a hydraulic fluid change. When was this done last? Fresh gearbox oil should also help a little to glide into gear.
oh really. Well i have never done it. So im sure it cant hurt. Ill try it.
yea like cander24 said put some nice new oil in.. mayde add some transmission oil additives that claim ot makes it easier to change gears (couldnt hurt)... if that doesnt solve the problem then i'd say your 1st gear synchros are probably worn.. and unless you wanna fork out for a reco you'll just have to live with it lol.. reco's arent cheap either.. unless you wanna try it yourself and get angry and frustrated and take a month to put it back together just to save a bit of cash like i did!.. i have a bit of a problem thinking i can do everythinglol.. went back together but.. feels great.. learnt a shitload.. and saved money... and if i did it again i'd do it in a weekend i think... lol
anyway back on topic... try the new oil and see how it goes..
Why do you wanna shift back to 1st unless you're going slow anyway? lol
also i agree.. short shifter is definately money well spent
Adam
Mate i am meaning Slow, less than crawling.
What does a reco consist of?
Does any one have any info on how to change the tranny oil? Like instructions or how to's?
Thanks
a reco consists of replacing all synchros, bearings and seals.. all that comes in a reco kit which includes new roll pins and clips and just all little bits and pieces inside the box... also anything else thats worn out like if any of you're gears are badly damaged you'd want to replace them...
ive never changed the oil in a getrag as i have a T5 in my car, however basically its the same as changing your engine oil... find the plug on the bottom and drain the old oil, screw the plug back in.
THEN im pretty sure will have to take your centre console off (just the part around the gear selecter not the whole thing) and pull the rubber boot around the selecter off.. now get under the car and find the fill plug and take it out.... get a piece of hose that fits into the hole (i just use garden hose)
and cut it long enough so it can go through the hole in the transmission tunnel down into the gearbox... now just fill it up through the hose to the amount of oil that is recomended.. and you're done =]
hope that helps
On the bottom of the gearbox towards the tailshaft you will see one bolt head (about 19mm from memory) remove this and this wil drain your gearbox oil. Once this is all drained put the drain bolt back in and then remove the filler bolt plug which I think is the same size as the drain one. It is located on the drivers side of the gearbox near where it says "Getrag" on the alloy casing. Just fill it up then until the oil overflows and comes back out of the hole then put the plug back in. It should hold just under 2 litres from memory.
I did mine recently and was able to fill it up from under the car using the extendable hose that comes on a Penrite gearbox oil bottle.
But I would also seriously be looking at flushing the hydraulic clutch fluid as any bit of air or condensation in the line will affect its operation and how smooth it is. This should be changed as often as you bleed your brakes.
I had a similar problem on my old mini (yeah I know its not a commodore, but there you go). Mechanic said the syncro on 1st never lines up as well as the rest so if you are stopped before you put it into gear put it in 2nd THEN go to 1st. Will line it up much easier. If you are slowing down just come to a stop in 2nd. You won't need to shift back all the way to 1st when you are moving all that often.
And change your gearbox oil more often than you normally would will help you extend the life of it a bit
awesome guys, Thats a great help. What oil do you recommend? synthetic or what?
Ill go take a look at it now then get some oil tomorrow.
Thanks
I'm not sure what it takes, but you should find the specs in your owners manual.
Getrag takes 80-85. I know Penrite make this but if you shop around there will be plenty of others that make this weight gear oil if you have a particular brand preference.
I have only been able to get some 70-75 penrite? is this going to be okay?
I have been contemplating purchasing one of these shifters for so long i need someone to convince me pleaseDoes anyone have any photo's and hopefully a video or 2 as i would really like to hear about some more info on one of these before i fork out the $450 odd dollars for it for my VS 1997 5 Speed Ute.
Thanks Heaps
Matt
back to basics mate. oil to thin= box to noisy, box to hot, shortend oil life coz the load is to high
if it were me and this is just my own opinion...........oil is cheap....... getrags are not, the oil will do for a week or two of easy driving, but do once! And do it right!
Thats surprising as most places i've looked in the past all carry the 80-85. I would be inclined however to hold out for the right grade rather than use something too thin. Any of the auto places you've looked at will be able to order it in no worries. Go with the right grade of oil, bleed your clutch and hopefully it should fix all your dramas.
