Results 1 to 3 of 3
Thread: Code 76 - HELP!
    VS Calais Series II
    Feb 2009
    Default Code 76 - HELP!
    Hi guys i have started a thread on a bad fuel economy and since then i changed the 02 sensors. the engine light didnt come on but when i pulled the codes just to double check i got:
    Code 76 - Air/Fuel ratio variation between left and right banks
    Now i know what this means that the right side bank and left side bank have significantly different air/fuel mixtures.
    I was wondering if anyone has experienced anything like this and what the problem could be.
    Im sort of leaning on to fuel injectors.
    Anyone know why and what to do?
    Keep in mind i have really bad fuel economy aswell.
    THANX TO ALL
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    What do you consider really bad fuel economy?
    A difference in AF ratios between banks usually indicates a vacuum leak or an injector problem on one bank.
    Have you reset the ECU, driven it, then checked the codes again?
    Visit my Facebook page
    VS Calais Series II
    Feb 2009
    Well i was getting bad fuel economy like 330KM per full tank.
    trip computer showing 20+L / 100KM
    Just an update flushed radiator, threw some injector cleaner and cleaned the earth points on the 02 sensors and changed the earth wire to a thicker one for the -'ive terminal.
    Car started to splutter alot. So i firstly made sure no water was on the leads etc from radiator flush.
    Then i guessed it was the injector cleaner. So i took it on a long drive gassing it hard and it all smoothed out.
    Just topped up with premium and reset ecu.
    now trip comp shows 15L/100Km after a short drive.
    So im guessing my injectors were clogged bad.
    I will check for codes again and see what happens.
  1. vn ss wat is code 12
    By winton in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-10-2008, 06:38 PM
  2. code 47???? WTF!!!!
    By maco_butterfly in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-03-2008, 08:52 PM
  3. VR S2 Code 31
    By Bob Cox in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-05-2006, 09:03 PM
  4. Code 13... Again
    By jack.mc in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-11-2005, 05:06 PM
  5. Code 14 what the hell is error code 14!@*&%#
    By Danzilla in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-05-2005, 12:35 PM
