Results 1 to 8 of 8
Thread: Questions regarding VR wagon smokey engine and power steering "hiss".
    VR Commodore Wagon
    May 2005
    Default Questions regarding VR wagon smokey engine and power steering "hiss".
    Hi guys,
    I have a '93 3.8ltr VR wagon, and absolutely love it, but i find sometimes when i start my car, especially if it hasnt been started in a few days, it gets embarrassingly smokey! This seems to die off as the engine warms up, but it kinda looks like ive got a James Bond smoke machine until then! I have just had it serviced, so it has new oil, oil filter and sparks.
    I was wondering what the common cause of smokey engines are, and where would be a good place to start looking to solve this problem.
    Also,
    When i turn my stearing wheel, i hear a "hiss". Now, i figure its the power steering leaking, but what i would like to know is what needs replacing, and what sort of cost would this be?
    VR Commodore Wagon
    May 2005
    I dont know if this makes any difference to the smokey engine question, but my wagon is an auto.
    VS Exec
    Mar 2005
    Default valve stem seals?
    Could be your valve stem seals causing the smoke only when you start it after leaving it a while.
    VT HSV Senator Sig 195i A4
    Jul 2004
    I would say Koontz is spot on with the engine smoke at start up. My car does the same, a big puff of smoke and then returns to normal. Doesn't do it every time you start it up, only on the odd occasion. Yes it is a little embarrassing Don't think it's anything to be too worried about , just need to keep and eye on ya oil level.
    VR Commodore Wagon
    May 2005
    kapiti holden Guest
    yep sounds like seals, see if it smokes when you take off from lights as well, if it does it is the seals
    VR Commodore Wagon
    May 2005
    Cool - can anyone tell me an approx. cost on getting a mechanic to replace these?
    dontsailbackwards is offline I didn't do it
    VR Calais V6 '94
    Apr 2005
    Hey - does it use coolant ? Mine has done a valley gasket and is also blowing a puff of smoke if I start it hot after about 15 minutes. I think it's coolant leaking into the inlet manifold. Just a theory ...
  1. yep, another "what is causing the noise" questions
    By commod8 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-02-2007, 06:12 PM
  2. Is the warning "service engine oil" the same as "check oil" ?
    By morris in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 04-12-2006, 04:36 PM
  3. LPG in VT Wagon which tank, Conventional or "Donut"?
    By muso in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-08-2006, 08:19 PM
  4. VT II Acclaim wagon door and tail gate "creaks" when going over bumps.
    Last Post: 22-08-2006, 11:11 AM
  5. The "gears" and "power" in an auto
    By nath_120 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-07-2006, 08:59 PM
