Results 1 to 7 of 7
Thread: Air con condenser
    OzJD's Avatar
    OzJD is offline Not your average Joe.
    VR6 S1 & VR6 S2
    Feb 2009
    Parramatta, NSW
    Default Air con condenser
    Hey guys, Just wondering if anyone has changed an air con condensor in a VR?
    Is it straight forward? Any hints?
    When I went to get re-gassed the pipe between the condensor and receiver dryer cracked (drivers side of receiver dryer)
    Anyhow, my wifes compressor on series II VR is rooted, so I was gonna use hers to fix mine... any advice? (Can't find any how to's)
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Can't help you much except to tell you this is a common problem - read somewhere that it's caused by the compressor oil getting on the threads of the nut that clamps the aluminium pipe to the drier and the oil reacts when in contact with the atmosphere and does something strange to the aluminium....the oil used in the compressor is not "ordinary" oil! Also remember reading that you need to be very careful when attaching/removing the nut that hold the pipe on and use 2 spanners. Remember not to get any oil on the threads.
    Good Luck.
    OzJD's Avatar
    VR6 S1 & VR6 S2
    Feb 2009
    Parramatta, NSW
    Exclamation
    Yeh i just took a look and it looks like the whole condensor has to be changed over, not sure what ill need to do to change it over, anyone?
    The whole nut that is near the receiver dryer has exploded (it went kaboom!) and gas went everywhere!
    I should post up a pic of it
    woteva's Avatar
    woteva is offline NEED 4 SPEED
    VRII V6 Auto Wagon
    Jul 2005
    Adelaide S.A.
    I had mine done a few years ago. From memory, they had to take the front bar off, and also they cracked my windscreen trying to get the plastic panel off where the windscreen wipers are.
    http://woteva.tk/
    If it ain't broke... I can break it for you
    OzJD's Avatar
    VR6 S1 & VR6 S2
    Feb 2009
    Parramatta, NSW
    OzJD's Avatar
    VR6 S1 & VR6 S2
    Feb 2009
    Parramatta, NSW
    So no one can hint to me the easiest way to remove it?
    OzJD
    Current mods/repairs:
    Power Windows Installation (70% Complete)
    Current Issue(s)
    N/A
    My Holden doesn't leak, It's just marking it's territory!
    Quote Originally Posted by 88GreenVN View Post
    Missing teeth from the diff is terminal as in diff no worky. Crunch crunch bank snap and then STOP.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    It should be pretty straight forward as long as you are extra careful when undoing the flange nuts on the pipes...make sure you use 2 spanners and avoid putting any stress on the aluminium tubing. You'll need a new receiver/dryer and the special (nitrile?) "O" rings to suit. At a guess I'd say the easiest way to remove the whole caboodle would be to remove the front bumper which is just a few screws and clips. Seal the end of pipes etc to prevent moisture etc entering the system as this will cause corossion and block the TX valve. There are some good articles on playing with aircons on google - in the US you can do re-gassing yourself.
    From the look of your old dryer it probably is the original.
  1. VR A/C Condenser Nut Cracked
    By Bilbs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-03-2008, 12:56 AM
  2. A/C condenser problem
    By dawg in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-01-2008, 09:02 PM
  3. Air Con Condenser
    By fergies in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-12-2007, 02:09 PM
  4. removing condenser
    By Keesh in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-04-2007, 08:28 PM
  5. Wtb:vn Aircon Condenser
    By CAM05L in forum Swap / Wanted to Buy / Trade
    Last Post: 17-01-2007, 02:49 PM
