Results 1 to 13 of 13
Thread: Stubborn Leads on Ecotec!
    VS Acclaim S2
    Feb 2009
    Hackham West
    Default Stubborn Leads on Ecotec!
    Ok here we go,
    I thought I would save myself some dollars and change my spark plugs n leads myself, so went out and bought some NGK plugs and top gun leads. Thats all sweet But....
    When i came to taking the stock leads off to get to the plugs they just wont move at all. I have sat there yanking, twisting, jiggerling up n down n side to side but they just wont move!!!
    I have lil metal surrounds on the leads due to them being so close to the headers(came with car). seems like the rubber behind the metal is stopping it from coming off, like it has a super wack seal on the plug.......
    only tried the passenger side of engine due to its the easiest side to get to and dont wanna do 1 side and not the other.....
    Is there any trick to this or is my leads just a Bitch!!!
    Help!!!
    haha
    Cheers Rhys
    commodore VX SS SII
    Feb 2009
    adelaide
    VS Acclaim S2
    Feb 2009
    Hackham West
    VS Calais Series II
    Feb 2009
    Mate just grab pliers and pull them out. even if they fall apart your changing them anyway.
    The metal clip that is on the actual spark plug must be stiff if that breaks off you can just remove it later.
    there's no special way of remiving them apart from pulling them as hard as you can.
    Has it got those metal housing around the outside if so try pulling that out a little then pull on the leads.
    commodore VX SS SII
    Feb 2009
    adelaide
    you have new leads right? hold the lead in your hands about half way up and pull like you have never pulled before should come of
    VS Calais Series II
    Feb 2009
    Maybe try remove the lead from the coil side first that way you have more free lead and just grab it and rip it off and see how you go.
    you'll get better at it as you get to the last one
    Just make sure you know which size lead goes where. as you take them off measure it to a new lead and mark it with the number matching to the coil and plug.
    greenacc's Avatar
    greenacc is online now Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    mine were like that when i bought my car. Just have to pull them off. try twisting as well. they will be stuck on from the heat, so if ya can twist em they will come off. Hako posted a pick of some special long pliers he uses, try searching for that.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by greenacc View Post
    Stone the crows greenacc - you've got a long memory! I'll attach the pix - got them at Bunnings for a dollar or two from one of the tables where they throw things out that they can't sell however auto shops carry them. You use them to grip the metal heat shield or the connector and twist and pull at the same time. You could use long nose pliers at a pinch...just remember to twist as well as pull and if you want to re-use the lead only pull on the connector. Good Luck.
    Attached Thumbnails Attached Thumbnails Stubborn Leads on Ecotec!-pliers.jpg
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Not sure about how much room the six's have, but at a pinch just cut the lead off at the plug and use a small flat screw driver the get under the rubber cone over the plug and unstick it off the plug and rip it off.
    Reaper
    VS Acclaim S2
    Feb 2009
    Hackham West
    Cheers for all the advise fellas, ended up gettin a pair of those pliers and they worked good.
    VrWagz1's Avatar
    May 2008
    wollongong
    nice, we assumed you may have fixed it
    Reaper
    S2 VX V6 Berlina Wagon, 304 VL Berlina Wagon.
    Feb 2009
    Sydney, Little Bay..
    haha i also had this problem when i was changing my plugs last week, ended up screwing one of the leads so just started yanking them out, Best thing i ever did. haha
    with the new leads she feels like a new car. haha... also i've changed leads on many cars many time but it was my first where it made me bleed..
    VS_Pete_1's Avatar
    VS_Pete_1 is offline Donating Member
    VE II SV6 MY12 Sportwagon
    Dec 2007
    I got a pair of gloves from supercheap no blood no burns one of the best things i have brought.
    "Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
    My VS II Berlina Wagon
    MY12 II SV6 Sportwagon
  1. V6 Ecotec Sparkplug leads
    By batemada in forum General
    Last Post: 25-05-2008, 05:02 AM
  2. Changing spark plug leads on ecotec?
    By vh-holden in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-10-2006, 05:06 PM
  3. spark plug leads for LPG (ecotec v6)
    Last Post: 28-11-2005, 11:05 PM
  4. Removing stubborn crap on car body
    By craigvk in forum General
    Last Post: 08-11-2005, 12:28 PM
  5. High tension leads - Ecotec
    By DJ Majah in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-04-2005, 12:29 AM
