Page 1 of 2 12 LastLast
Results 1 to 25 of 26
Thread: lsd in vs?
    WogBoyz's Avatar
    WogBoyz is offline Cammed & Eventualy Blown!
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    Question lsd in vs?
    hey everyone im just wondering is it possible to get an lsd in my vs ute, so everytime i hit a puddle it doesnt just slide, my dads ute has an lsd and his never slides out
    does anyone know how much and where i cud them i live in cairns so is it possible to get them locally here?
    Now Saving for a Harrop HTV2300 Supercharger kit!
    Quote Originally Posted by skyracer View Post
    On new years eve I got stopped by a pack of about 5 people forming a road block. All of them naked. They proceeded to turkey slap my car as I rolled past...
    greenacc's Avatar
    greenacc is online now Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    cheers man and while im here is there a thread on radators for a vs aswell cus the stock one is pretty shit small just wondering is it ok just change it with a bigger one?
    undar8ed1's Avatar
    undar8ed1 is offline Rags 2 riches!
    2 VXII V8 dailys
    Feb 2008
    regional W.A
    greenacc's Avatar
    VE Berlina
    Jul 2008
    hmmm, haven't seen a thread on big rads. I guess its pretty warm in cans most of the time, but my stock one works ok for me. I can't see you having a prooblem fitting a thicker one if u can find it, as long as you don't change the thermostat. Sure u don't have a small leak somewhere ?
    VS ute
    Nov 2008
    stock ones fine mate. i live in cairns and just so happen to own a vs ute aswell and mine is good as gold, maybe check for leaks?
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    oh nah its working great, no leaks or anything like that , i was just wondering if it is possible to get bigger ones i though the cooler the engine ran it would be better living in cairns, cus sitting in traffic with aircon on it gets pretty damn warn under the bonnet
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    narh man its ok once i lower mine it shud handel better n i read somewhere when u change ur diff ur speedo is off so not going to that much trouble, thanks anyway dude
    greenacc's Avatar
    VE Berlina
    Jul 2008
    Your speedo only goes out if u change the gear ratio in the diff. If you fit an LSD with the same ratio as your original unit , no worries.
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    where would i be able to get a lsd diff in cairns tho?
    dufus is offline Donating Member
    rickshaw
    Jun 2006
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    kk ill give the wreckers a call n see how it goes, ill ask for a lsd for a vs ute that shud know ey?
    rickshaw
    Jun 2006
    Quote Originally Posted by WogBoyz View Post
    Yeah, any decent wrecker should know.
  15. #15
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    awsome cheers for ur help bud
    oh btw could i just get any mechanic to install it for me?
  16. #16
    rickshaw
    Jun 2006
    Yeah i dont see why not, any mechanic should know what they are doing. If there is a place that specializes in diffs in your area I would suggest you go there though.
  17. #17
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    alright ill scope it out
    thanks for all the help i appreciate it
  18. #18
    Enter the Model/Class of your Commodore. i.e. VL C
    Sep 2008
    in my opinion it should have one already,
    all vs Utes came out the factory with a LSD as standard.
    I'm guessing a previous owner has changed it or locked it.
    crawl under her and see what it has written on it there should be a tag on the middle bolt on the drivers side see what
    it says if it says "high performance" it is or once was a LSD.
    if not ring around your local wreckers and see what they have from memory there where some good ones around cairns but
    i cant remember which 1's or where they where LOL.
    hope i helped
  19. #19
    danja's Avatar
    danja is offline Swerves for gay koalas
    CBF 250 and a Levin ZR
    Mind Me Bloody Beer Champion!
    Jan 2006
    You mean when you drive into a puddle, or when you accelerate in the wet? An LSD isn't going to help you drive through puddles, good tyres will do that, LSD is only for putting power to the ground.
    DANJA'S CLEAROUT 2010 : Various VT-VZ parts, short shifters, performance parts. Check it out!
    Quote Originally Posted by Reaper
    I think Joe Hockey is one of their best performers and I hope he gets [around] quickly - for everybody's benefit.
  20. #20
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    kk ill check today fuzzy, cheers for the help lads
  21. #21
    TUF UTE's Avatar
    TUF UTE is offline Dave
    05 VZ SENATOR
    Nov 2008
    adelaide
    your ute should have a lsd, id say someone has done doughies in it
    any borg warner diff basically dies straight after any side ways action.
    v8 and v6 lsd diff are the same aside from different gear ratios
    i work as a instrument technician and specialise in speedo and just swapping diff wont change anything speedo wise if it has same ratios. look at the back of your diff and see if it has a little metal tag on it that says lsd.
    SIR LS1
    the two ton go kart
  22. #22
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    oh ok nah an older lady had it b4 i did so dont think she was doing them lol, and i havnt done any only slid out in the rain few times but thats it, ill give it a check disarvo it pro has a lsd
  23. #23
    TUF UTE's Avatar
    05 VZ SENATOR
    Nov 2008
    adelaide
    it should if its vs ute. might be loose.... jack the car up so both rear wheels are off the ground and turn one wheel and see what the other one does
    SIR LS1
    the two ton go kart
  24. #24
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    alright well i checked the tag and it said "lsd high preformace" guess i had one the whole time and didnt even know it musta been the crap 16 stock wheels that used to make me have no traction the new 18inch rims n low profiles are much safer and look awsome too
  25. #25
    rickshaw
    Jun 2006
    Is prob worth an oil change too, made a world of difference to my LSD
LinkBacks (?)
  1. 24-02-2009, 11:26 PM
